Race Engine Weights
+23
2fox
peganit2
D-CEL
Larry Williams
Kevin93
brianhaeckel
665 falcon
deliveredfast
511Fox
jts557
racnrick
27 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Re: Race Engine Weights
We should make this thread a sticky..................
richter69 wrote:We should make this thread a sticky..................
Should maybe include all the bbf blocks in if you do But good idea sir
deliveredfast- Posts : 358
we get some pictures posted.. I'll personally make it sticky
138- Posts : 1593
138 wrote:we get some pictures posted.. I'll personally make it sticky
HeHe,that pic w/reg. bracket is now sticky
Awsome post Charlie Thanks for taking the time
Great
This is the Greatest Website ever.
511Fox- Posts : 251
Very interesting thank you .
665 falcon- BBF CONTRIBUTOR
"2. Mike's engine. FRPP SVO block, 4.530" X 4.300" (I think? Lem?), P-51 heads, Victor, single QFT carb, water pump. 641 lbs."
If you are refering to Mike M's engine...the bore is but 4.420". So it didn't have much wt. bored out of it.
I really don't know were the 300# + wts. for the as delivered A460 blocks comes from. We got two in tuesday, both blocks including their crates and the pallet they both were straped to were less than 600#. I suspect the 290# that Rick qouted is closer to correct.
Okay Lem, thanks for the correction. I'll go back and change the bore size in the original post.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
IDT Premier with 4.650 bore = 254#
Older A460 with 4.650 bore and filled to bottom of water pump holes = 265#
A460 block with TFS A460 heads, TFS cast tunnel ram, CSR water pump, Peterson Wide Vac pump, Danny Bee belt drive, steel oil pan, complete engine(4.65x4.15) less carbs was 655#
Weighed all of these a couple years ago on one of my chassis scales. Hope this helps
Brian
Brian
brianhaeckel- Posts : 4
An IDT Eliminator block with a 4.680 bore, bronze lifter bushings installed & LSM CNC litening program weighs approx. 204 lbs without the roller cam bearings installed. Thanks & have a nice night!!!!
Kevin93- Posts : 67
any updated info ???
c.evans wrote:Guys,
I've been doing some checking lately, with an very accurate and zeroed 1000 lb scale, of the BB Ford engines we've had going on the dyno lately. All engines were weighed without flexplate or starter, but with oil, carb and etc . In other words I've made sure that the comparisons are valid.
1. Bobby's engine. DOVE-A block, 4.442" X 4.500" = 559 CID, Milodon splayed 4 bolt main caps, P-51 heads, Victor, single 1250 QFX carb, Mezeire electric water pump. 600 lbs.
2. Mike's engine. FRPP SVO block, 4.420" X 4.300" (I think? Lem?), P-51 heads, Victor, single QFT carb, water pump. 641 lbs.
3. Todd's engine. FRPP SVO block, 4.600" X 4.500"= 598 CID, TFS A-460 heads, TFS 2 X 4 tunnel ram manifold, two QFT 1150 carbs, Mezeire electric water pump, Moroso vacuum pump, dry sump pump and lines, Peterson dry sump tank, & nitrous plumbing. 735 lbs.
4. Jeff's engine. DOVE-A block, 4.440 X 4.500"= 557 CID, short fill HardBlok, Milodon splayed 4 bolt main caps, TFS A-460 heads, TFS single four intake manifold, alum. mechanical water pump, single QFT carb. 627 lbs.
I hope this is helpful,
Charlie Evans
Where is number 5 Charlie? I need to order front springs as I am replacing the old gabriels on there now and the weight would be a huge help.
Larry
Larry Williams- Posts : 884
Larry,
To answer your question,,,,,engine # 5 is an all alum. block 598 CID engine with TFS A-460 18 bolt heads and a TFS single plane intake manifold. Complete with carb, oil, flexplate, internal Kaase oil pump, vacuum pump but no starter,,,,it weighs 556 lbs.
Hope this helps,
Charlie
Hope this helps,
Charlie
thanks charlie thats just what I was looking for.
Hey Guys,
Fantastic! I can contribute too! LOL
My unmachined A96 weighs 160lbs
Jason
Jason
D-CEL- Posts : 13
nascar429 likes this post
What made that first engine comparatively lighter then the rest?
peganit2- Posts : 55
Talked to some chevy boys about that 600# number, and the 559 cubes. They were pretty quiet.
peganit2 wrote:What made that first engine comparatively lighter then the rest?
Answwer;
1. The block was a stock production block and it was lighter than the aftermarket blocks.
2. The alum. P-51 heads are fairly light in weight. They are an OEM style CJ head.
3. The FRPP Victor single plane intake manifold was lighter than the bigger A-460 or C-460 single planes.
4. The #1 engine that was weaighed was Bobby Shrewsberry's engine and he won Super Pro at the 2010 Ford bash with it.
Hope this helps,
Charlie
c.evans wrote:peganit2 wrote:What made that first engine comparatively lighter then the rest?
Answwer;
Hope this helps,
Charlie
Not sure. The next lightest with p51's is +41#.
Any more reasons why #1 was that much lighter?
I would LOVE to get a BBF around 600lbs for my Fox Mustang, and I just want to know what it takes.
Engine #2, (Mike's) had P-51 heads, but the 41 lb. difference in engine weight can be attributed to the SVO A-460 block. That's Ford aftermarket racing block with really thick cylinder walls and siamese cylinders, also a beefier bottom end.
Charlie
Charlie
c.evans wrote:Engine #2, (Mike's) had P-51 heads, but the 41 lb. difference in engine weight can be attributed to the SVO A-460 block. That's Ford aftermarket racing block with really thick cylinder walls and siamese cylinders, also a beefier bottom end.
Charlie
Oh sorry missed that little detail.
Excellent information!
Have you ever weighed a 408 W ? With stock block.super victer intake.victer jr heads.ect?
I would like to know how much heavier the bbf would be thanks
2fox- Posts : 275
2fox wrote:Have you ever weighed a 408 W ? With stock block.super victer intake.victer jr heads.ect?
The published shipping weights of FRPP crate engines which also include the pallet:
392 "Z" engine = 545 pounds
521 with A460 block = 700 pounds
514 with production block = 670 pounds
» Engine shut off during race.
» Cooling a race engine
» race engine challenge
» Race Engine EFI build
» PLEASE POST PICS OF YOUR ENGINES !!
Page 1 of 3
