Gas vs Alky........
+27
Larry T
jsracing
Wes Littrell
QtrWarrior
56Tbird
johndickjr
BigDave65
Maddmattmustangs
Treeyasoon
knrclark
KY JELLY
Moodyblues
31 posters
Page 2 of 5
Page 2 of 5 • 1, 2, 3, 4, 5
Re: Gas vs Alky........
The fuel companies are just adding oxygen content to the gas Q-16 is an exotic expensive race fuel .
I am willing to offer my car to you gas tuner guys friday at the bash to prove to me it will in fact run faster and more consistent on gas. I will supply my injection and my fuel , I also have 10 gallons of q-16. If you want it done with a carb someone will have to supply it and an electric fuel pump.
Lets settle the question and quit wondering about it .
KY JELLY- Posts : 1530
bygod!KY JELLY wrote:The fuel companies are just adding oxygen content to the gas Q-16 is an exotic expensive race fuel .
We run "gas" if you consider Q16 gas. It cost about $11.75 per gallon in bulk and we don't use that much. Our VE numbers are right around where NA numbers are on efficient engines. Smells aweful and it gets if your nose and mouth and you can't get it out.
I ran C16 and alky in my old junky mid eleven second maverick and the times were the same and I won a bunch of bracket races in both E and No-E and I footbraked in both. I preferred the C16 but I have buddies that love the alky.
whatbumper- Posts : 3024
As Charlie mentioned....the biggest moves you will see in E.T., are usually caused by changing track temps....not by changes in DA. If you have a combo that makes big moves with the air, whether you are on gas or alky, your tune-up is wrong....period. The current Super Pro points leader at my home track is running a tunnel ram with 2 dominators on gas....car is deadly.
Again, track temp will dictate E.T. change long before a change in the air will.
To answer the OP's question....I run gas....Renegade 110.
Treeyasoon- Posts : 759
alcohol gets you laid, end of story
Consistent is a good working race car that is properly driven. Which fuel is in the cell don't matter.
"The fuel companies are just adding oxygen content to the gas Q-16 is an exotic expensive race fuel"
J.Y. , why do you always referance Q16? The facts of the matter are that most people running gas do not use it.
VP113 is bad fast gas and is $290 a barrel cheaper than the Q16. Bobby Shrewsberry used the 113 when he won the "Bash" last year..........I guess it was because his ride was inconsistent and slow
In the words of Ricky Bobby.................... "If you dont run methanol then f-ck you.........."
they both are oxygenated I could buy 2 barrels of methanol with that cost savings or one barrel and a 5 gallon bucket of liquid mono-propellant
I believe the biggest reason guys use alky is so they can bring tears to their opponents eyes while sitting in the staging lanes trying to get heat in the thing!
Just give me some good ole' Sunoco 112
BigDave65- Posts : 567
No trouble getting up to temp here, I use block and an oil pan heater, If I get stuck
in the lanes the primer plus will bring it up in a hurry.........I guess gas is good for that lol
KY JELLY wrote: they both are oxygenated I could buy 2 barrels of methanol with that cost savings or one barrel and a 5 gallon bucket of liquid mono-propellant
Did anyone say 113 was not oxyenated? That's a good thing BTW or did you forget that methanol carrys a lot oxygen?
At only $41 a drum more than 110 it does not fit your " an exotic expensive race fuel" statement.
I have excess to the same carb Blake made the 1,003 HP with and I have repocessed my 80A-0 pump .
sounds like yall need to do the pepsi challange and get it over with...............
richter69 wrote:sounds like yall need to do the pepsi challange and get it over with...............
One vote for Coke.........
Methanol is distilled at that and no oxygen additives added. All race gas is at least 3 times the cost of methanol
Are we wanting to compare plain non oxygenated gas to plain methanol or oxygenated gas to oxygenated methanol ?
I am ready to do it and quit talkin about it
Taste great............... no Less filling................
Down nozzle 85% 15% at the throttle body , injected Q-16......................
injection will save the carbuu---rators reputation
I am going fishing in my gas powered boat that I just had to replace the gas hose ends because of artifically oxgenated pump gas
IDT-572 wrote:Taste great............... no Less filling................
Injected at the runner, and the plenum..............with a little Mr. Frosty for good measure............
"I am ready to do it and quit talkin about it"
So quit talking .
So quit talking .
cousin car runs 11.00--11.02 every pass...uncle car runs 10.00-10.02 .even in the 102 degree Oklahoma heat...both use av gas..lol
johndickjr- Posts : 896
Where in the hell is Justin at??? He needs in on thisjohndickjr wrote:cousin car runs 11.00--11.02 every pass...uncle car runs 10.00-10.02 .even in the 102 degree Oklahoma heat...both use av gas..lol
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:Where in the hell is Justin at??? He needs in on thisjohndickjr wrote:cousin car runs 11.00--11.02 every pass...uncle car runs 10.00-10.02 .even in the 102 degree Oklahoma heat...both use av gas..lol
Dan he is on summer brake
With his cousin's uncle's sister's ex-boyfriends dad ,....I Forgot!!
Pepsi ond/or 'Dew > coke.
DILLIGASDAVE- Posts : 2262
What does alky cost? What does M5 cost? How much fuel do you burn per pass and what is the cost per pass for fuel?
The only prices i know currently are on my buddies ride and he is running oilfield alky.
» Finally making some progress
» Engine reliability: Alky vs Gas
» My new alky set up
» Going to Alky
» alky
» Going to Alky
» alky
Page 2 of 5
