Gas vs Alky........
+27
Larry T
jsracing
Wes Littrell
QtrWarrior
56Tbird
johndickjr
BigDave65
Maddmattmustangs
Treeyasoon
knrclark
KY JELLY
Moodyblues
31 posters
Page 3 of 5
Page 3 of 5 • 1, 2, 3, 4, 5
Re: Gas vs Alky........
could'nt tell you about M5 but just your good ole 55gal drum from the local co op is 170$ish in my area.i burn about a gal a pass.the warm up and idle time with alky is where i use much more,over gas deal.whatbumper wrote:What does alky cost? What does M5 cost? How much fuel do you burn per pass and what is the cost per pass for fuel?
The only prices i know currently are on my buddies ride and he is running oilfield alky.
methanol $2 per gallon here little less than a gallon per pass just say $2 / pass
M-5 $6 per gallon little less than a gallon per pass just say $6 / pass
methanol + nitro for home brewed oxygenated methanol which will not be rivaled by any type of race gas about $38 / 5 gallon jug @ 18% mixture 5 passes fer $7.60 a pass
Q 16 $12/ gallon I would guess 1/2 gallon per pass ? $6 / per pass
1 enderle 5" throttle body injector with pump $1450
1 enderle bird catcher with pump $1700
2 1250 race carbs with pump $2,400
KY JELLY- Posts : 1530
1 gallon of alky per run.......... 2 bucks
1 pound of Mr. Frosty 2 bucks, 1 pound per run.
M5 depending on price at the time 5-6 bucks, about 1 gallon per run.
DILLIGASDAVE wrote:Pepsi ond/or 'Dew > coke.
Got to have something to mix the Alky with.......
Any vp oxygenated gas is oxgenated with tert-butyl methyl ether which is manufactured via the chemical reaction of methanol and isobutylene , so high end race gas is mixed with something also. There is nothing wrong with it we all want to make more power , but the more you look at things, it looks like the best gas is a mixture of good old methanol and gas
dfree383 wrote:DILLIGASDAVE wrote:Pepsi ond/or 'Dew > coke.
Grapefruit juice . with salt around the rim of the glass!
Lem Evans wrote:J.Y. , if you want'd to save money you'd still be running the borrowed 1050
That was a good carbytooter Charlie's 533 seemed to like it about a tenth better than the gas one , but not sure it would like the nitro
Hay Lem that's me
"2 1250 race carbs with pump $2,400"
____________________________________________
Who said anything about two carbs? J.Y. , if I ever get into politics will you be my speech writer ?
If need them I got a matched set of clean low lap 1250s........$2,425 for both.
carbs is too hard to tune...............
richter69 wrote:carbs is too hard to tune...............
I know......a guy would have to buy a screw driver. It's unlike a the barrel valves where one can work on them with their bare hands
Lem Evans wrote:richter69 wrote:carbs is too hard to tune...............
That's funny right there...I don't care who ya are !!! lol
QtrWarrior- Posts : 2703
QtrWarrior wrote:Lem Evans wrote:richter69 wrote:carbs is too hard to tune...............
Doug can get a test drive on the 1250s if he wishes...
injected alky is real easy to change the fuel on,add or take out with a pill change.if i had to run a carb i'd run gas too.
I made some changes over the winter and was suprised.I have ran one toilet,two toilets, and a buzzard catcher all on alky with virtually no difference in et on my a460 headed engine.So I would say I have a pretty good baseline on alky.The best my truck ran on alky was 5.50 in good weather and average was 5.55.I switched to a borrowed 1050 gas dominator and went 5.45 this spring.Better 60' ,et, and mph.Seemed like it was going to be just as consistent.Now according to everybody a 1050 should be way to small for a 572, but it worked quite well for me.I now have an 1150 so we will see how that goes.My truck would burn a little over 1 gal a pass on alky, now I went 6 passes on around 2.5 gal.I was running just strait alky vs 110.I our area alky is around $2.15 a gal vs 110 is $5.65,so in my case gas is cheaper, if you throw in the oil changes.Now I have nothing against running either, but in my case gas was faster.I know my engine isn't a all out build, I shift it around 7000 to 7200, and I think it is a good representation of a typical bracket engine.We will see how gas does in the heat of the summer at the bash.The thing that I like about gas is how good it starts at any temp, and the fact that the oil looks the same coming out as it did going in.Just my two cents.
Wes Littrell
Wes Littrell
Wes Littrell- Posts : 647
Wes Littrell wrote:I made some changes over the winter and was suprised.I have ran one toilet,two toilets, and a buzzard catcher all on alky with virtually no difference in et on my a460 headed engine.So I would say I have a pretty good baseline on alky.The best my truck ran on alky was 5.50 in good weather and average was 5.55.I switched to a borrowed 1050 gas dominator and went 5.45 this spring.Better 60' ,et, and mph.Seemed like it was going to be just as consistent.Now according to everybody a 1050 should be way to small for a 572, but it worked quite well for me.I now have an 1150 so we will see how that goes.My truck would burn a little over 1 gal a pass on alky, now I went 6 passes on around 2.5 gal.I was running just strait alky vs 110.I our area alky is around $2.15 a gal vs 110 is $5.65,so in my case gas is cheaper, if you throw in the oil changes.Now I have nothing against running either, but in my case gas was faster.I know my engine isn't a all out build, I shift it around 7000 to 7200, and I think it is a good representation of a typical bracket engine.We will see how gas does in the heat of the summer at the bash.The thing that I like about gas is how good it starts at any temp, and the fact that the oil looks the same coming out as it did going in.Just my two cents.
Wes Littrell
Good info. Wes.
and whats the wt. on that hot rod??
res0rli9- BBF CONTRIBUTOR
2450 +320 driver .
Dang................I still run gas. The C12 vp is 8.50 gal where I live. Ive seen seen a couple guys in the area running hats and cant seem to get them right on alky. One is on engine #3 in two years. Some others run alky carbs and seem to do ok.
old thread not digging up bones but whatever became of the challenge? did you swap to a carb KY?
my 2 cents is for a NA combo it could probably go either way depending on engine size and tune up, air density.... etc.
for forced induction ? methanol is definately the choice of the quicker blown cars but you see some very fast No2 cars with big in motors on gas..... and some very fast turbo cars on gas.
I think Hamstra, taylor, Mike janis etc are all on methanol
How about a diesel engine with alky fuel? https://www.youtube.com/watch?v=oTMdLvvHBnI
Curt- Posts : 2791
I've sat in that stadium and watched 4 straight days of tractor/truck pulling. It was a blast.
schmitty- Posts : 4538
I like alky in a drag car, but I LOVE alky in a single engine tractor.
Curt- Posts : 2791
Gonna give the gas a shot again and see what happens, it'll get an n/a pass or two then the hose gets turned loose..........
» Finally making some progress
» Engine reliability: Alky vs Gas
» My new alky set up
» Going to Alky
» alky
» Going to Alky
» alky
Page 3 of 5
