Nos timing ??
jason
Nos timing ?? Empty Nos timing ??
Post  jason July 30th 2011, 6:50 pm
I sprayed a 200 plate out of the hole and it only went 9.66 and NA it goes 9.80s . So im wondering is it a converter issue or did I pull put to much timing and or put to much fuel in?I pulled 6* out .
jason
jason
Nos timing ?? Empty Re: Nos timing ??
Post  bruno July 30th 2011, 8:46 pm
What is the tune on the plate
http://WWW.CKRME.COM
Post  DILLIGASDAVE July 30th 2011, 8:59 pm
What do the plugs look like?
Post  jason July 30th 2011, 10:07 pm
I can't remember the jets on the kit , but the porcelain was a light brown , the fire ring was alittle sooty and the electrode changed color at the bend .
jason
jason
Post  richter69 July 30th 2011, 10:45 pm
whats the converter flash to and what rpm drop on the shift with Mr. Frosty on?
and the n/a times, was that the same night or back in the better air.....cuz it sure sucks right now.
Post  jason July 30th 2011, 11:12 pm
richter69 wrote:whats the converter flash to and what rpm drop on the shift with Mr. Frosty on?
it was the same day , it flashes to 4800 roughly and it's a 9" 5400 , I didn't look to see what it drops to on the shift . The trans is a coan glide with a 1.76 first gear and the car weighs 3500 rolling
jason
jason
Post  Larry T July 31st 2011, 12:58 am
are you sure the nitrous came on all the way through the run?next thing im comserned about is u runing 1/4 mile for the first time on the frosty jug.what plugs are you useing.ngk is what most people use that are on nitrous.word is if you hurt the plugs on autolites you are most likely done,hurt the ngk it may not be as bad.do you have a deadicated fuel regulator for the nitrous and did you flow the regulator?
were you up aganst your upper revlimit during the nos run?
Larry T
Larry T
Post  jason July 31st 2011, 1:49 am
Larry T wrote:are you sure the nitrous came on all the way through the run?next thing im comserned about is u runing 1/4 mile for the first time on the frosty jug.what plugs are you useing.ngk is what most people use that are on nitrous.word is if you hurt the plugs on autolites you are most likely done,hurt the ngk it may not be as bad.do you have a deadicated fuel regulator for the nitrous and did you flow the regulator?
yes I use NGKs . I just rewired the car but yeah think it's coming in all the way . I have one fuel pump and regulator , the pump is a magnafuel 500 it maintained 7 lbs of fuel psi the whole run . Alot of guys here use one pump on a 300 kit I'm only going to 250 which is as high as the kit goes.
jason
jason
Post  whatbumper July 31st 2011, 2:44 pm
the one pump is fine, it's the one regulator that will get you into trouble. and your cam could be hurting you too if it is only for NA.
Your converter is probably too loose on the spray. RPM drop on the shift is a very important piece of data to know on any race car with a glide especially.
Post  Larry T July 31st 2011, 9:13 pm
holley sales a great little regulator for about 26.00 and alot of people use them as a second regulator for nos setup.7lbs is were my fuel to carb is set and the regulator for the nos is flowed to 5lbs for my setup.
if you had the 2nd regulator flowed at 5 lbs to start with (probably a little rich for the 200 shot) you maybe in the 9.40's range like you are.
i had the 9" ptc 00 converter that flashed to 5600 then went with a 9.5" and it still flashes at 5600 but on the shift it pulls it down good when on all motor Smile when im on the Frosty bottle i can here pull down some so i know i can put the bigger pills in when needed.
Larry T
Larry T
Post  jason July 31st 2011, 10:31 pm
Can I tee off the main fuel line before the carbs regulator to the fuel solenoid regulator ?
jason
jason
Post  jason July 31st 2011, 10:34 pm
I'm gonna make a few N/A hits in 3 weeks first to see how the suspension is working I made a few small adjustments on the fourlink hoping it 60s better then I'll throw the smack to it
jason
jason
Post  whatbumper July 31st 2011, 11:13 pm
jason wrote:Can I tee off the main fuel line before the carbs regulator to the fuel solenoid regulator ?
yes. Thats normal.
Post  Induction-Solutions August 1st 2011, 12:57 pm
Unless I missed something there's also a lot of unknowns here too ???
A "200 shot" can mean many things ??
What system and jetting and fuel pressure ???
You say you took 6 degrees out ??? Out of what base ??
What's some details on the combo ???
What did your bottle weigh before and after the run ???
Did you try and turn on from the start to the finish ???
What's the car weigh ???
What were the 60, 330, 1/8 before and after ??
Just trying to get a better idea on what's going on.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  jason August 9th 2011, 7:58 pm
There are a few things I can't answer until after the 26 , 27 , 28 of this month when I getback from brainerd minn. I'll write everything down .
jason
jason
Post  Induction-Solutions August 12th 2011, 11:05 pm
That will work.. We'll be around.. SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  jason August 28th 2011, 10:53 pm
Ok I just got back from bir and I'm starting to narrow it down on the bottle , this is my first attempt with a big block and yesterday I ran a personal best 9.78 @ 139 N/A at 36* total and my first pass on the bottle was a 9.31 @ 134 with 6* pulled out . The second bottle pass i pulled 5* and it slowed down to a 9.43 . I'm going back this weekend I think the jet was alittle fat so I'm gonna mess with that .
jason
jason
Post  bruno August 29th 2011, 10:25 am
jason wrote:Ok I just got back from bir and I'm starting to narrow it down on the bottle , this is my first attempt with a big block and yesterday I ran a personal best 9.78 @ 139 N/A at 36* total and my first pass on the bottle was a 9.31 @ 134 with 6* pulled out . The second bottle pass i pulled 5* and it slowed down to a 9.43 . I'm going back this weekend I think the jet was alittle fat so I'm gonna mess with that .
CONGRATS VERY NICE PASSES !!!!
Post  jason September 5th 2011, 10:44 pm
Thanks .... I just got back from BIR and dropped my times again , I maxed out my cheater kit and went 9.11 @ 147 , so now I think I'm gonna have to call induction solutions and send them my intake . I wanna put a fogger on it with the big solenoids , I wanna get in the high 8s to start with plenty of room to go faster .
jason
jason
Post  Induction-Solutions October 26th 2011, 8:26 am
Great to hear you had a little fun and got a NPB.. if we can help you further please let me know.. Thanks, SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  1970 ford maverick October 28th 2011, 10:38 am
You said ,I maxed out my cheater plate!, What jets,fuel pressure,timing ?,Can we hear more about your Mustang?,It runs as good as it looks,We like that alot !. THANKS,MAV MAN
1970 ford maverick
1970 ford maverick
