ENGINE BUILDERS! Please look
'65 T-BOLT
blown86hallet
ENGINE BUILDERS!  Please look Empty ENGINE BUILDERS! Please look
Post  blown86hallet August 8th 2011, 12:20 pm
Most of you have seen my boat?
Now that it's finished, it's time for another boat.
This time I want to do a "K" boat... Only issue is ALL "K" BOATS ARE CHEVY POWER.
here is a video, of "K" boats. Please watch.
470 cui limit.
8-71 blower. (most are spinning them 45 - 50%) about 25 lbs boost. about 1,200 - 1,500 hp
alky injection.
running off the snout of the crank.
engines are turning 7,200 - 7,500rpm for 5 laps. some times they see 8,200rpm.
I have been chatting with one "K" boat owner, he is a FORD man, but has to do the Chevy in the boat "Because he was told so!"
his combo.
474 cui
8-71
Dart block.
Heads not sure ( sure they are aftermarket aluminum)
Billet crank
Oliver rods.
Pedestal rockers. (i would go shaft)
wet sump oiling.
nothing special in his build!
ALl the engine builders say "Fords wont last as in a K boat." Maybe they are thinking OEM ford stuff?
I want to prove these guy's wrong.. I see no issue with a Ford living!
a-460 block,
billet crank,
oliver rods,
shaft rockers
Heads (issue will be blower intake!) but 18 heads bolts would be IDEAL!
TFS, or P-51. Would really like Boss 9!
tell me your thoughts!
adam
Last edited by blown86hallet on August 8th 2011, 12:36 pm; edited 3 times in total
blown86hallet
blown86hallet
ENGINE BUILDERS!  Please look Empty Re: ENGINE BUILDERS! Please look
Post  '65 T-BOLT August 8th 2011, 12:23 pm
Adam,you can always build it and prove them wrong!
'65 T-BOLT
'65 T-BOLT
Post  blown86hallet August 8th 2011, 12:28 pm
'65 T-BOLT wrote:Adam,you can always build it and prove them wrong!
yes I know, and I want to so badly! but why do they say "FORDS" can't live.???
blown86hallet
blown86hallet
Post  rmcomprandy August 8th 2011, 2:23 pm
Because THEY just don't know any better ... use a 2 lobe, straight lobe rotor; (not the most efficient however, the biggest GULP per revolution being that the class is limited to just an 8-71). The over-all weight of the crankshaft has a lot to do with it but, that can be compensated and the snout diameter driving the supercharger; (no problem).
EDIT: I have built a couple B.B. Ford "White Water Jet Boat" engines and there hasn't been any problems with the oiling of an A460 block.
Post  QtrWarrior August 8th 2011, 2:33 pm
Adam,
Have not forgotten about your PM.... Give me a day or so....I'm sure we can work something out you'll like.... Twisted Evil Twisted Evil
QtrWarrior
QtrWarrior
Post  blown86hallet August 8th 2011, 4:34 pm
I do know of this Jet boat racing! I think I seen a Kasse engine being run! Monster of a boat. Good pooint!
Spencer king is the boat owner!
blown86hallet
blown86hallet
Post  Frank Merkl August 8th 2011, 10:49 pm
looks to me the driver needed a rest!!! after that workout!!!
Post  rmcomprandy August 8th 2011, 11:59 pm
ADAM ... There is a little more to Whitewater Racing than that video shows as they run up shallow rivers for miles against the current through rapids and rocks and whatever else they encounter. The boat is built like an aluminum lightweight "Sherman Tank" with a race engine.
https://www.youtube.com/watch?v=3i2Q0ZzwgxU
https://www.youtube.com/watch?v=2XgpefTyCJY
Post  Doug Rahn August 9th 2011, 8:38 am
The White Water racing is really cool, but the Sprint Boats are what I like to watch. Small boat with hugh horsepower Cool I would love to build one of these just to play in on the back creeks of the Savannah River.
https://youtu.be/DIJjGkeHPzY
