Wrist Pins For Nitrous Engines
Beast
What brand, material and wall thickness of piston pins are you guys using in your nitrous engines?
Beast- Posts : 66
Re: Wrist Pins For Nitrous Engines
The H13 tool steel pins from Trend do a good job...... .185" wall on most cases...depends on the amount of spray.
Lem Evans wrote:The H13 tool steel pins from Trend do a good job...... .185" wall on most cases...depends on the amount of spray.
this is what i just put in my new motor hoping to spray 300-550 on one kit and 200-400 more on the second kit
studly- Posts : 512
studly wrote:Lem Evans wrote:The H13 tool steel pins from Trend do a good job...... .185" wall on most cases...depends on the amount of spray.
res0rli9- BBF CONTRIBUTOR
details?
138- Posts : 1593
Beast wrote:What brand, material and wall thickness of piston pins are you guys using in your nitrous engines?
So , what pin did you deside on?
I'm going to go with the Tool steel H13 Trend pins as you suggested. I'll be using up to a 300 shot of spray, is the .185" wall sufficient?
Beast- Posts : 66
Beast wrote:I'm going to go with the Tool steel H13 Trend pins as you suggested. I'll be using up to a 300 shot of spray, is the .185" wall sufficient?
Now that you got'em they better be
You should be good to go.
I haven't actually got them yet.
Beast- Posts : 66
138 wrote:studly wrote:Lem Evans wrote:The H13 tool steel pins from Trend do a good job...... .185" wall on most cases...depends on the amount of spray.
details?
Just caught this.
New Motor is a SBF the Pistons are Diamonds the Wrist pins are actually quite a bit thicker than the .185 wall this is a motor i have been working on for the past couple of years to deal with the power in the class i have been running in. it is a Nitrous Only motor. i am going to the Dyno actually 11/3/2011 I am hoping for over 800hp on motor with N02 fuel. I am just tunning the motor for now for the spray that will be coming soon. LoL I will post some pictures later tonight hope knowbody gets offended since it is just a SBF.
studly- Posts : 512
Should be good at .185".
studly wrote:138 wrote:studly wrote:Lem Evans wrote:The H13 tool steel pins from Trend do a good job...... .185" wall on most cases...depends on the amount of spray.
details?
Just caught this.
Being that the sbf pin is smaller in dia. a thicker wall yet may be the ticket.
Just checked and they are H-13 .200 this is with a .866 pin instead of the standard .902 SBF pin moved some stuff around to get a stronger piston with more compression height. I hope all this stuff works.
studly- Posts : 512
hmm, how much spray will the wrist pins take that come with probe pistons ? my shit might be living on the edge.
10SHOTS- Posts : 587
Shortblock
studly- Posts : 512
studly- Posts : 512
Thanks Adney Brown for the clearancing and balance job
studly- Posts : 512
» Pressed wrist pins
» Questions about wrist pins
» 5100 series Chromoly wrist pins
» Pleas post pics of your Nitrous Engines !!!
» For Sale/NITROUS NOS PROGRAMMABLE NITROUS CONTROLLER #15834
