how to adjust valves on stock 460
When I replace the seals - what's the best way to adjust the valves? The way I remember is with the engine running, back off till they tick, then tigthten 3/4 turn..
sasilverbullet- Posts : 9
Re: how to adjust valves on stock 460
Typical stock 460's do not have adjustable valve trains, just torque the rocker to the specified torque.
Or you have a early one with Rail / Cast Rockers, CJ / SCJ or PI Engine?
Or do you have an engine that has been converted to an adjustable valve train with studs and guide plates?
as he said,do you have a 1/2 head bolt, if so 18 to 24 ft lbs, if you have a stud with a nut we need more info ,because theres a few different styles
BOSS 429- Posts : 2372
ok, will find out - may not be till later this evening...but I think it's just the stock 1/2 inch bolt.
if you ever are working on adjustable rockers the process you described is a terrible way of adjusting. With engine not running, tighten nut till you get zero lash and then give 1/2 turn (only on adjustable hydraulic lifters) while following firing order
cooter- Posts : 220
I have the factory manuals and double-checked what they said - basically it's just torque the bollts to 18 - 22 ft lbs.
The detail in the manuals is crazy detail! I wish they'd put stuff like that out for today's cars...
» how big valves in a460 heads with .080 overbore on stock block
» the dove c heads i bought , i measured the intake valves they were 2.250 assuming these are not stock valves ?
» Max RPM for stock valves
» Stock dove valves
» P I valves ( stock Ford) FOUND No longer needed
» Stock dove valves
