tuning questions
badcoupe
Induction-Solutions
studly
tuning questions  Empty tuning questions
Post  bruno November 15th 2011, 7:56 am
well here are all three passes from sunday
pass #1
82n 73 fuel , 5.5 fp @ 20*
1.277
3.616
5.549
125.10
pass# 2
same tune but @ 22*
1.235
3.531
5.440
128.84
pass#
same tune but @ 24*
1.249
3.552
5.456
128.86
so the 22* seemed the happiest , but the plugs were still rich my questions are :
1- what timing should i start to take fuel out ?
2- if i take fuel out of the 20* will it pick up more then running rich @ the 22* ?
3- once the plate is dialed in what #s should i be shooting for/ goals ?
4- and then finally once i get the plate dialed in closer what is it going to take on the fogger to run low 5's ?
http://WWW.CKRME.COM
tuning questions  Empty Re: tuning questions
Post  whatbumper November 15th 2011, 9:40 am
I would take fuel out of the 20degree setup and work the timing up from there.
Bring that thing to Texas and I will take out 300+ lbs out of that thing without changing the outside appearance.
Post  bruno November 15th 2011, 10:19 am
whatbumper wrote:I would take fuel out of the 20degree setup and work the timing up from there.
lol .... yah what change drivers Laughing
Post  studly November 15th 2011, 11:45 am
do you have any pics of the plugs from each pass?
studly
studly
Post  bruno November 15th 2011, 11:55 am
studly wrote:do you have any pics of the plugs from each pass?
nope , but after the 2nd pass i pulled a couple of them and the ceramic was not clean
Post  studly November 15th 2011, 12:01 pm
I would start with the 22 and pull .5 pound a fuel pressure and watch the et. How much timing was in the strap at 22?
studly
studly
Post  bruno November 15th 2011, 12:11 pm
studly wrote:I would start with the 22 and pull .5 pound a fuel pressure and watch the et. How much timing was in the strap at 22?
honestly i pulled the plugs and didnt pay any attention to the straps
Post  studly November 15th 2011, 3:16 pm
OMG STEVE IS GOING TO GET YOU FOR THAT ONE
studly
studly
Post  bruno November 15th 2011, 3:18 pm
they were ngk and they were all still intact Laughing ...if that counts
Post  Induction-Solutions November 25th 2011, 1:59 am
With those numbers the 22 looked pretty good. But also knowing it could use less fuel, I would go back down to the 20 and maybe add .004 to the nitrous side jet and go from there..
You are going to have to watch the plugs as well to really learn what your combo wants.. Wink Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  badcoupe December 1st 2011, 5:10 pm
good job bruno - now hit that bitch harder maybe youll finally beat my street car cheers j.k happy for you bud Very Happy
badcoupe
Post  psfracer December 2nd 2011, 10:05 pm
What fuel are you guys running with nitrous? C16? I run Q16 on motor only but was told to switch from that when I start spraying.
psfracer
psfracer
http://www.psfracer.com
Post  badcoupe December 2nd 2011, 10:11 pm
I run c 12
badcoupe
Post  richter69 December 2nd 2011, 10:21 pm
meth....... Very Happy
Post  John Myrick December 3rd 2011, 6:10 am
richter69 wrote:meth....... Very Happy
friggin alky's Razz
Post  bruno December 3rd 2011, 8:29 am
badcoupe wrote:good job bruno - now hit that bitch harder maybe youll finally beat my street car cheers j.k happy for you bud Very Happy
thanks ......... Very Happy
psfracer wrote:What fuel are you guys running with nitrous? C16? I run Q16 on motor only but was told to switch from that when I start spraying.
im running c16
Post  studly December 3rd 2011, 2:43 pm
I ran c16 on my big block up to 300hp worth of nitrous, anything over that i switched to vpno2
studly
studly
Post  bruno December 3rd 2011, 3:31 pm
studly wrote:I ran c16 on my big block up to 300hp worth of nitrous, anything over that i switched to vpno2
did you change your tuneups with the vpn02 fuel ?
Post  psfracer December 4th 2011, 12:13 pm
What compression do both of you run?
psfracer
psfracer
Post  badcoupe December 4th 2011, 12:15 pm
Not sure who your talking about but I'm 11.1 and make 830 n/a hp
badcoupe
Post  yellowhorse7 December 4th 2011, 12:17 pm
psfracer wrote: I run Q16 on motor only but was told to switch from that when I start spraying.
Who told you that?
yellowhorse7
yellowhorse7
Post  bruno December 4th 2011, 12:25 pm
13.1
Post  bruno December 4th 2011, 12:26 pm
Who told you that?
you can run Q16 for fuel you just need to watch the plugs/tune very carefully
Post  psfracer December 4th 2011, 1:06 pm
Who told you that?
bruno wrote:
Who told you that?
Yeah, that is what they were getting at, not that Q16 wouldn't work, but for more of a safety margin run the VP N02
psfracer
psfracer
