Pos unit
Pos unit Empty Pos unit
Post  IDT-572 16th December 2011, 19:48
who makes a limited slip unit for the Ford IFS on a 97 F-250?
Pos unit Empty Re: Pos unit
Post  dfree383 16th December 2011, 19:59
http://www.richmondgear.com/powertrax/fordtrucklr.pdf
Richmond offers a couple different ones, heres the Powertrax
Post  IDT-572 16th December 2011, 20:00
i NEED TO FIND OUT IF ITS A 44 OR 50
Post  dfree383 16th December 2011, 20:00
http://www.richmondgear.com/powertrax/lockright.html
Post  dfree383 16th December 2011, 20:01
IDT-572 wrote:i NEED TO FIND OUT IF ITS A 44 OR 50
Yep
Post  strokedmyford 16th December 2011, 20:31
http://www.justdifferentials.com/ these guys are real helpful and will remember your name when you call back.
strokedmyford
strokedmyford
Post  schmitty 17th December 2011, 01:04
Blake, I'm pretty sure that they only used the 50's on the diesel trucks.
Post  strokedmyford 17th December 2011, 13:48
big lockout=50 small lockout=44
strokedmyford
strokedmyford
Post  Diggindeeper 19th December 2011, 10:17
After about 1985 or so D50 was your only choice for the F250 HD's
Before that apparently you could get them with a 44 although I've never seen one myself
Diggindeeper
Diggindeeper
Post  IDT-572 19th December 2011, 14:42
It's a 50 and seams I need to go to manual hubs to run the limited slip or locker if driving on ice.
Post  Diggindeeper 19th December 2011, 21:29
IDT-572 wrote:It's a 50 and seams I need to go to manual hubs to run the limited slip or locker if driving on ice.
I guess for precaution reasons. I only ever had the manuals.
What is the purpose of the locker. Is this for off roading or mearly to have an extra wheel spinning in case?
Diggindeeper
Diggindeeper
Post  IDT-572 19th December 2011, 23:32
Just changing from 4.10's to 3.55's and thought I would put in a pos unit while the front end was apart, it has a limited slip in the rear.
May not fool with it, my brother had his F350 dual wheel stuck this morning with 15 6x6 round rolls of hay on his goose neck trailer, and I went down and pulled him out with the open diff, probably not worth the trouble. Rolling Eyes
Post  Diggindeeper 20th December 2011, 00:48
That's where I was going, with a rear ls these trucks are pretty capable.
Diggindeeper
Diggindeeper
Post  bbf-falcon 27th December 2011, 22:55
Mine is a 97 and it has a 50 series. Got a set of 3.55's if you need some Blake.
