more delays
more delays
here's the problem. im using a dual stage nitrous system and my 60' go down when using spray mid 1.5s to 1.8s. this is the system first stage 50hp 42n 36f 5psi fp 30* wot switch activated. second stage 150hp 65n 52f 5psi fp 26* digiset activated .9 sec out. im thinking about activating the first stage with a digiset timer .5 to .10 sec. to help with the 60' or not use first stage justsecond stage
quick 52- Posts : 612
Re: more delays
With that small of hits i would only use one kit, and i would use digiset to delay untill car/truck would hold.
studly- Posts : 512
Re: more delays
You need to use as much as possible out the gate. Is 50hp all that your car will hold? If not keep bumping up until you find the limit. Then you will need to work on your second stage. How much do you want to spray on this system and you need to keep moving closer to the start until you find the limit. I leave on 250 and grab another 150-175 .6 out. I can bump it to .4 on some good tracks.
valleydawg- Posts : 427
Re: more delays
that the problem it wont hold 50hp kind of need to delay the hit .5 to .10 sec. out to get hooked. thinking about another digiset to delay the first hit like the setup with dual stage system can run 50hp or 150hp or both the way it is. the truck is way nose heavyvalleydawg wrote:You need to use as much as possible out the gate. Is 50hp all that your car will hold? If not keep bumping up until you find the limit. Then you will need to work on your second stage. How much do you want to spray on this system and you need to keep moving closer to the start until you find the limit. I leave on 250 and grab another 150-175 .6 out. I can bump it to .4 on some good tracks.
Re: more delays
Progressive Controller would work good and cotrol the hit for you. Can you run one or are they illegal in your class?
studly- Posts : 512
Re: more delays
im not in a class just bracket. just playing around with it cant use the hose at the track truck doesnt have a roll bar and run 11.50 on motor. during t&t i have hit it alot trying to dial it in. @ drag week they would let u get alittle crazystudly wrote:Progressive Controller would work good and cotrol the hit for you. Can you run one or are they illegal in your class?
