Valve diameter measurement?
Valve diameter measurement? Empty Valve diameter measurement?
Post  HorsinAround January 30th 2012, 2:47 pm
I received a bare set of oem iron heads that a truck puller had used several years ago. What do I measure to determine what valves it is set up for? He can't remember, so I'm trying to figure out what I need to look for.
http://www.frontpagefab.com
Valve diameter measurement? Empty Re: Valve diameter measurement?
Post  bruno January 30th 2012, 7:20 pm
if i was going to measure them i would from the 45* cut , can you tray a valve thats close and use some of that blue stuff to mark the diff ...... im sure the head gurus would chime in
http://WWW.CKRME.COM
Post  rmcomprandy January 30th 2012, 8:46 pm
bruno wrote:if i was going to measure them i would from the 45* cut , can you tray a valve that's close and use some of that blue stuff to mark the diff ...... im sure the head gurus would chime in
YEP ... measure the outside diameter of the seat.
Post  HorsinAround February 13th 2012, 5:30 pm
Ok, from the measurements, I believe they are the stock diameter. These heads are D2OE-AB's. So if my research is correct they require 2.19 and 1.72 valves with .341 diameter stems. Question is what length do i need? The cam I plan to use is a .600 lift.
Thanks again for your help.
Post  rmcomprandy February 13th 2012, 7:01 pm
HorsinAround wrote:Ok, from the measurements, I believe they are the stock diameter. These heads are D2OE-AB's. So if my research is correct they require 2.19 and 1.72 valves with .341 diameter stems. Question is what length do i need? The cam I plan to use is a .600 lift.
The stock production intake valve diameter in a Police Interceptor head was 2.200", (5.185" long, 30 degree seat) ... the stock production exhaust valve diameter was 1.725", (4.978" long, 45 degree seat).
Post  HorsinAround February 14th 2012, 9:48 am
Thank you for the reply. Will I need a longer valve with the bigger cam lift?
Post  rmcomprandy February 14th 2012, 11:13 am
HorsinAround wrote:Thank you for the reply. Will I need a longer valve with the bigger cam lift?
Maybe ... maybe not.
It's all about whether or not you can get the correct valve spring installed height.
Post  HorsinAround February 20th 2012, 1:17 pm
Would you happen to have a part number or where I can get them?
Post  bigblok2000ranger February 20th 2012, 5:40 pm
Competition Products
Part# E2903-1(change the one to a 8 for full set) $12.99 each
Part# I2904-1(again change the 1 to 8 for full set) $13.29 each
I have used Competition Products valves in 4 different builds with zero issues and long service life.
Competition Products 1-800-233-0199
These are one piece severe duty stainless steel valves.
bigblok2000ranger
bigblok2000ranger
Valve diameter measurement? Empty spring height
Post  HorsinAround March 8th 2012, 3:41 pm
What is the correct valve spring installed height? I bought an intake and exhaust valve from Comp. products and put them in along with a retainer and locks. From the casting seat to the underside of the outer step of the retainer I measured 1.925 on the intake and 1.976 on the exhaust. Also the recommended spring for the cam I have is a comp cams 928 if that helps.
