Eddy head 460 with icon pistons
+16
99zx9r
jm
gmsmkr
butterbean
quick 52
1fatcat
meandad
mudtrucker
5pointslow
20 posters
Page 3 of 5
Page 3 of 5 • 1, 2, 3, 4, 5
Re: Eddy head 460 with icon pistons
supervel45 wrote:Are you going to have the engine balanced?
Yes to balancing ......even if stock rods were used figured it can't hurt even at lower rpm
vs some others builds that scream to 7k plus
5pointslow- Posts : 1408
I think I would still stick with the cam Blake recomended, and not push the hypers too hard.
supervel45- Posts : 4499
Thats the plan
going to use cam he suggested
thinking of going with those h beams , but at same time may use the stock truck rods that have arp bolts in them. I have thought if im willing to buy h beams ...why stop there get forged pistons as well . Then that defeats the purpose of using what i have
i had the pistons from another engine and rods , and had a ground 10/10 crank that was never ran is the reason for the build . Instead of selling each piece i figuared i could put together a low $ motor for now . plus i have a set of eddy cj heads 75 cc out of the box not ported that would work .
balancing the setup i feel is a must ....even if i use stock rods are used
supervel45 wrote:I think I would still stick with the cam Blake recomended, and not push the hypers too hard.
stock rods ...i think put chip at 6300-6400 max and shift at 6k
5pointslow wrote:supervel45 wrote:I think I would still stick with the cam Blake recomended, and not push the hypers too hard.
Ok now nail it down and stick to it and have some fun....................
IDT-572 wrote:5pointslow wrote:supervel45 wrote:I think I would still stick with the cam Blake recomended, and not push the hypers too hard.
thats the plan keep it simple and all goes well should have this all set for start of next season ( hope before that ) our track closes in October
http://asheville.craigslist.org/pts/5109849673.html I would see if this guy still has these. It's about a month old add but you may get lucky.
http://www.460ford.com/forum/showthread.php?t=123202 I doubt Paul has anymore, but you can read about them, and see the 2008 price.
Viktor or torker2 for an intake ?
Victor. !!!!!!
5pointslow wrote:IDT-572 wrote:5pointslow wrote:supervel45 wrote:I think I would still stick with the cam Blake recomended, and not push the hypers too hard.
Atco is open through the first week of December.
Good luck with the build.
99zx9r- Posts : 39
been thrashing on car ......
bought a set of h beams to go with the KB hypers ( figuare rods be more forgiving)
should get 10.5 to 1 compression .
I have a viktor intake but could sell and get a tfs mafia if any gain could be had ? Trying to get most out of what i have for now but could sell intake i guess to get another one ..i dont know
heads are out of box eddy 75 cc .... going to get with someone to do a custom solid flat tappet cam to get the most of it.
550-575 hp is my goal
5pointslow wrote:been thrashing on car ......
Should have kept the stock rods and bought better pistons. Can yhey last? Yes, so long as it never rattles and the ring gaps follow or exceed kb direction. Seen a handfull of hypers in the pan, because street warriors doing cheap added hose.
kim- Posts : 700
No nitrous being used ....fyi
NA combos detonate too... just less dramatically, usually.
kim- Posts : 700
I agree ... I think i will be ok at this hp level and if i went with better pistons my luck id have rod failure ....i had the engine this pistons came out of and basicly over hauling it with a light hone . cylinders are near mint an mic up great
5pointslow wrote:I agree ... I think i will be ok at this hp level and if i went with better pistons my luck id have rod failure ....i had the engine this pistons came out of and basicly over hauling it with a light hone . cylinders are near mint an mic up great
Build it, beat it, enjoy it.
Some times we kill ourselves with how can we make it bullet prof, only to spend 1000's and still have something we outgrow, blow up, or just get bored with.
We all sit back and tell you how you could have, should have, etc....... yet, every lap you make, is one you made without our enlightened input.
Build what you have, best of luck, and enjoy.
kim- Posts : 700
kim wrote:5pointslow wrote:I agree ... I think i will be ok at this hp level and if i went with better pistons my luck id have rod failure ....i had the engine this pistons came out of and basicly over hauling it with a light hone . cylinders are near mint an mic up great
^^^^^^this.... and the best part is there will be time to upgrade and make it more when you get ready
gmsmkr- Posts : 1364
Looking for 10.00 to 10.50 to index race ....i really dont need a ton ...hell could use a small block if needed
Do you have the small block parts to make a 10sec build laying around?
gmsmkr wrote:Do you have the small block parts to make a 10sec build laying around?
No ...point was shouldn't take a ton of power at 2700-2800 lbs to go those times....... the eddy heads I have are cj cnc port openings to use to help the issue
Keep the Victor.5pointslow wrote:been thrashing on car ......
need a sfi balancer .... prob will buy the ford racing one but will see whats out there first
https://www.429-460.com/t22928-turbo-547-bbf-project-part-out-idt-block-a460-heads-etc Did you see this one?
to this https://www.uempistons.com/installation_instructions/kb_installation.pdf
if my math is correct for drag race gasoline
.0329 top ring end gap
.016-.017 for second ring end gap
.002-.0045 piston to wall clearance
For a 4.390 Bore
For a 4.390 Bore
» New Eddy Heads?
» Icon 4.500 pistons
» Bunch of Parts for Sale (DOVE block, headers, cam, rods, misc)
» ICON Pistons
» icon forged pistons
» ICON Pistons
Page 3 of 5
