Eddy head 460 with icon pistons
+16
99zx9r
jm
gmsmkr
butterbean
quick 52
1fatcat
meandad
mudtrucker
5pointslow
20 posters
Page 4 of 5
Page 4 of 5 • 1, 2, 3, 4, 5
Re: Eddy head 460 with icon pistons
5pointslow wrote:gmsmkr wrote:Do you have the small block parts to make a 10sec build laying around?
No ...point was shouldn't take a ton of power at 2700-2800 lbs to go those times....... the eddy heads I have are cj cnc port openings to use to help the issue
I was getting at you have the parts to do a big block rock on with your plans...... it might just suprise you
Good luck have fun and keep us posted on how she does
gmsmkr- Posts : 1364
seems the bbf surprises a lot of people with simple combos , i could build a crazier engine but to slow it down for the class ...no need
turning 27 in a couple months and paying for a wedding currently out of pocket for spring .......should call this the WEDDING BUILD lol
so trying to use some things i already have and will spend some but didnt want to build a new engine from scratch .
finished redoing my house i bought last year ....been busier than ever .
could go crazier but local class is 10.50 index thats pretty big class .....should be simple combo to get to work
My thing is a finding a good starting point TIMING for this engine with hyper pistons , will use vp113 even with the compression at 10.7 to 1 ...i have use dto it before and have had good luck with it being consistant .
5pointslow- Posts : 1408
Did you even call this guy and see what he will take for the Ford Racing balancer?supervel45 wrote:https://www.429-460.com/t22928-turbo-547-bbf-project-part-out-idt-block-a460-heads-etc Did you see this one?
supervel45- Posts : 4499
Sent pm earlier
OK. I did not no if you had seen it, or his phone number in the long add.
supervel45 wrote:OK. I did not no if you had seen it, or his phone number in the long add.
Thanks I appreciate it
I know of a offy port o sonic for Dommy ..... I have a viktor but thinkin of grabbing it locally for 100 $
Not sure if any gain up to 6500 rpm max vs viktor , will probably grab for money though
Maybe only gain is stock hood with that Intake
Grab that intake now for a $100 dollars even if you don't use it, they are hard to come by and pretty good.5pointslow wrote:I know of a offy port o sonic for Dommy ..... I have a viktor but thinkin of grabbing it locally for 100 $
Guy is local next town over ...i can grab this week . if i recall i have seen some have good results with them .
I know the viktor is good , maybe the port o sonic with the 1050 will be better for my rpm range . not sure but im grabbing it
Butterbean said his ran as good as his Victor. I think the Dommy flange may be even more rare? Did you get those new truck rods in NC I posted for you on Craigs List for a $100.0? I should have grabbed them.
No to the truck rods ....grabbed a set of h beams , just bought the romac sfi balancer that went forsale on her ....the ford one was already sold
Gotta grab jw the wheel flexplate now for glide should be good ...
https://www.429-460.com/t23322-offenhauser-port-o-sonic-intake-for-sale I saw you got the Romac. I don't think this Offy is for a Dommy but, is port matched to CJ's? I should have written the Craig List guys phone number down, but I guess he sold them, the add is gone. For $100 you can't go wrong and no shipping charges either.
any chance the stock hood would work with a port o sonic ? ....... the stock hood look
for some reason i dont think it will but maybe close
http://www.edelbrock.com/automotive/mc/manifolds/ford/torker-bb.shtml This is the shortest one that I know of that might work for you. According to Edellbrock it is 2.05" shorter than the Victor. You will have to run a 4150 carb. though.
G dog ran 6.80's at 100 mph @ 4600 lb with a ported Torquer II I did for him. Through the muffs and street tires.
If it was good enough for a 545 shifting at 7000 rpm, I think it will be sufficient for your deal.
call me odd ....for some reason id love to run the stock hood vs the cowl
at the end of the day its a fairmont
Think it may clear ?
as reminder to this combo ....goal is to run 10.50 index faster would be better but think this is a realistic goal and class is pretty big at local track
using engine plates so maybe it will clear
http://www.yellowbullet.com/forum/showthread.php?t=84216&page=100 Look at the pictures in post #1492. You can get an idea of your hood clearance. I believe that is a Victor intake with a very tall air cleaner. A Torquer II would be at least 2"s lower and you could run a low profile air cleaner to make it fit?
thanks for posting that
should clear with just carb no filter
No problem, lot of cool Fairmont's in that thread.
Which intake? I believe he may have a one inch spacer on that Victor also?5pointslow wrote:should clear with just carb no filter
https://www.429-460.com/t23072-got-me-another-roller#268494
here is the car i have , previous owner had sbf with nitrous
supervel45 wrote:Which intake? I believe he may have a one inch spacer on that Victor also?5pointslow wrote:should clear with just carb no filter
mean if i use a torker 2 or port o sonic on my car
Yes or even the Victor looks close to clearing from the YB picks minus the air cleaner and spacer if it has one, could not tell for certain. I could not find the height of the Offy anwhere, but it looks around 5" from the carb pad to the china wall. The Torquer II is listed as 4.25" and the Victor at 6.30". Get your guy to measure the Offy.
» New Eddy Heads?
» Icon 4.500 pistons
» Bunch of Parts for Sale (DOVE block, headers, cam, rods, misc)
» ICON Pistons
» icon forged pistons
» ICON Pistons
Page 4 of 5
