What all do i need to switch my 460 to run e85
powerstrokeace
bigdaddy198
I just bought a 82 mustang with a 460/c6 have not even fired it up yet needs a few things but i want to find out if i would gain anything by. Converting this car to run on e85 all its going to be is a drag car what all do i need to look at to run e85 and will i be doing the right thing even thinking about it the 460 is a
mild build bigger cam dove heads 850 holley 10.5 to1 motor low miles on itwill it. Benefit me to run e85 in this
bigdaddy198- Posts : 31
Re: What all do i need to switch my 460 to run e85
Well first off you should get some runs on the car and try to fine tune it as is and know what works and what don't. Also we need more information on your build and what the fuel system consist of. E85 needs a large volume fuel pump do to the Fact that is burns 30-33% more fuel. if your car need to burn race gas you will in the long run save money because E85 is cheaper. I know of 2 great E85 builders, one converts you exisisting carb the other builds brand new stuff. You decide
Ace
Ace
powerstrokeace- Posts : 1496
A former fellow racer runs his car on E-85 he said he dropped .400 and gained 3-4mph on a 10.5:1 motor and car became deadly consistant. The guy shows up with his dial in on the windows already and has been same dial in for 2 years. He wins alot!
Very nice great info
I plan on taking it out asap and making some passes on it it has had the tank sumped and its running a holly blue pump and filter with bigger fuel lines up to the regulator then to the carb i have ran pro systems carbs in the past and i may contact patrick to see whats reasonable to get into. Thanks Guyz
Send your carb to Mark Sullens. Do a search on his name and call him and talk to him. He really know what he's talking about.
Ace
Ace
i built a 1050 dommy with a qft conversion kit and a few custom mods and mine works great...... The tuning window is HUGE with e-85 makes it a forgiving setup
jc10000rpm- Posts : 193
at 10.5:1 I'd just run 91-93 pump gas and not worry about converting it.
well tomorrows the day
i finally got the stuff i needed to fire this old 460 up by noon tomorrow i should be driving my neighbors CRAZY yeah
dfree383 wrote:at 10.5:1 I'd just run 91-93 pump gas and not worry about converting it.
If it's bound to be a bracket car the money would be well spent on E-85 conversion even at 10.5:1 in my opinion, heads up or an index maybe not so much.
bigblok2000ranger wrote:dfree383 wrote:at 10.5:1 I'd just run 91-93 pump gas and not worry about converting it.
I index race and switched last year thinking the expense of fuel $8.50-10.50 a gallons(2 cars) was pushing me out of the sport. I like the E85 but just have not work all the bugs out to run the number every time because of this throttle stop stuff. I may run all out brackets this year to see how things go.
Ace
For a 12-13:1 motor its a reasonable alternitive to race gas to save a few $$, but for a low compression perfromance engine its just not worth the agrivation IMO
dfree383 wrote:For a 12-13:1 motor its a reasonable alternitive to race gas to save a few $$, but for a low compression perfromance engine its just not worth the agrivation IMO
I certainly agree and run a 10.5 compression motor on pump gas and a 13.5 compression motor on E85. The 10.5 compression motor may be converted to E85 in the future but it will take advantage of the fuel and go up to at least 13 to 1.
As stated previously the fuel system needs to be oversized to handle the additional fuel at about 25% more.
That Holley blue wont last long with alcohol. I run an Aeromotive A1000 there are others and alcohol compatibility is a must including the lines and the regulator.
The E85 carb experts
Convert your existing carb with Mark Sullens or buy a new carb from Horsepower Innovations (Eric). Both are on the E85 websites. I went with a new 1050 Domminator from Eric.
Dave
Dave De- Posts : 797
» MSD rpm activated switch SOLD
» Head light switch problems
» electric pumps
» switch from a460 to???
» when to switch to a pro gear ?
» electric pumps
