need to know on say big cubes?
+6
2fox
10 posters
need to know on say big cubes? Empty need to know on say big cubes?
Post  2fox March 11th 2012, 9:20 am
I been doing research I see motors like 532 557's
I see some make.750ish and some say 1100 HP. Is this rwhp or.flywheel?
and what makes that much of a differance in power?
heads?
Cam?
more compression?
I don't think you can make say1000hp on 93 pump gas right?
And what's better a 532 or a 557 ? One will rpm higher that the other?
My 408. Has flattops and victor Jr heads around 12to1 at most cam is a solid roller with. 700 loft during @.050 is 268/278 super Victor intake with STD. Flange race.demon Carb 1000cfm.never dynoed it
All I know is my n/a MPH in1/4 mile is 124
on 200shot 138...that is running straight C16 car weight with me? Dunno
83 gt with AC box removed. Also have L/W Member with front coil. Overs flaming river rack.am 180lbs has f/glass hoodwhays dose. My numbers look.like on my little 408w on Nos and not on Nos?
I'm thinking of it more now. But you all know what is needed since I got no bbf stuff.what am liking at? Oil pan to Carb.I will need manual brakes. Or do they make a slim line brake booster.I'd really want power brakes of possible.I tried the manual set up on my 408 I went into the grass at the end of the track was damp and got sideways and almost. Didn't make it out the grass.
Thanks I will sit and listen. About the 750 to 1100 HP. 93 pump. Gas monster blocks
2fox
need to know on say big cubes? Empty Re: need to know on say big cubes?
Post  bruno March 11th 2012, 9:58 am
im not an expert but i did stay at a holiday inn once Very Happy .....
pump gas , money is no object , a massaged set of a460 heads and as much cubic inch ( 632+ ) , get someone like Lem Evans and Oakley Race Engines to put you together a complete package .meaning right cam and induction package .... i dont see were 1000 hp would be a problem
but cubic inches will be your friend on the pump
http://WWW.CKRME.COM
Post  bruno March 11th 2012, 10:03 am
btw here is an inexpensive magazine pump gas build
http://www.popularhotrodding.com/tech/0906phr_big_block_ford_engine/viewall.html
Post  2fox March 11th 2012, 10:11 am
bruno wrote:im not an expert but i did stay at a holiday inn once Very Happy .....
well I can say that that block may be out of the? But how mu h is it?
thinking I could sell my complete 408 has 13 passes. On it to have some cash plus some extra cash
Been awhile.since I stayed at a hoilday inn LOL.
2fox
Post  bruno March 11th 2012, 10:14 am
here is another BBF on pump gas
598 cubes at 1000 hp
http://bangshift.com/blog/dyno-video-a-598ci-1014hp-ford-big-block.html
Post  BOSS 429 March 11th 2012, 10:21 am
Post  2fox March 11th 2012, 10:46 am
bruno wrote:btw here is an inexpensive magazine pump gas build
yes that one I was checking out. So 1000 hp possible on 93 pump AND without nitrous correct?
2fox
Post  rmcomprandy March 11th 2012, 10:59 am
EVERYDAY ... and it is pretty easy.
NOT on the "cheap" though.
Post  dfree383 March 11th 2012, 11:10 am
X2 your not going to build a pump gas N/A 1000hp motor for a few thousand dollars.
The one bruno posted is probably $25K + complete
Post  richter69 March 11th 2012, 11:46 am
get rid of the pump gas and the cost per hp starts going down and is easier to get.
Post  2fox March 11th 2012, 1:18 pm
richter69 wrote:get rid of the pump gas and the cost per hp starts going down and is easier to get.
so more compression is cheaper?
2fox
Post  Barney March 11th 2012, 4:13 pm
You can build a lot more power with basically the same money until you start paying for fuel. The compression does simplify things. I figure if you can build 1000 hp you can more than likely afford a quality fuel.
Barney
Barney
Post  2fox March 11th 2012, 5:09 pm
Oh okay.yes it will be dragcar only.I don't run for the money nor the thropy. I. Just run for quickest ET.
dree383 said you can't build a 1000 hpmoror for 1000 bucks? Not sure what that meant?maybe it could be of I sell my 408 that
I got hell close to 10K in with the 13 passes maybe he thinks its only worth 800 bucks complete that is if I had 200 bucks in my wallet.? Not going to sell my 408for 1000 bucks.
Used block 300 bucks.
M/shop 500 bucks
buget rotating kit with balance &flywheel balance d. Say 1800.
heads lots to choose. From appx 2200/2600 bucks up
intake
pushrods.rockers.etc.
Solid roller can and lifters
dist. And wires.
oilpump.oil pan for fox body
Headsets
timing set
timing cover
Tall M/S V Covers
Carb......what else I'm FORGETTING? what total 13,000 bucks
radaitor big. One
and C6 Trans. Stall convertor
all ARP BOLTS
Gasket set.
2fox
Post  bigblok2000ranger March 11th 2012, 10:58 pm
I think you may have misunderstood basically these guys are saying its not be cheap, to make 1000 n/a on pumpgas is gonna require alot of cubes. What Richter is saying is with more compression same power can be made with less cubes. 750-850 is fairly striaght forward with 520-560 cubic inchs on pumpgas.
bigblok2000ranger
bigblok2000ranger
Post  cool40 March 17th 2013, 12:55 am
bump for hErO............ Razz
Post  richter69 March 17th 2013, 1:29 pm
bump for a good read
Post  85bigblockfox March 18th 2013, 9:58 am
Wish I had the funds
85bigblockfox
85bigblockfox
