WTB: Intake manifold for 429/460 with spreadbore pattern
ROAD RAGE
8man1320
I have shoehorned a 429 into my 67 cougar. It's awesome, but I have very little hood clearance.
I want to use the Thermo-Quad from a 74 lincoln 460.
I have D0VE-C heads, so no CJ intake.
Don't have room for the edelbrock RPM. (too high)
Ford used the TQ carb on some (all?) CA 460s in 74.
I need that intake. Don't know the casting number, never seen this part.
I am in the midwest, so I will need it shipped.
Serious buyer.
Please PM me here if you can help me out.
thanks
Serious buyer.
thanks
8man1320- Posts : 8
Re: WTB: Intake manifold for 429/460 with spreadbore pattern
8man I have a few,
You have pm..........
ROAD RAGE- Posts : 229
Have you checked out a Edelbrock torquer 2??? They are real close to a stock manifold height, might even be a little lower.
Last time I was at Lems he had a few of the Ford Racing ones on the shelf and they where priced right.
Torker intake uses the holley squarebore bolt pattern.
The one that I need takes a Q-Jet pattern.
The manifold for the ford spreadbore (4350) won't work either.
Primaries to close together, holley bolt pattern.
8man1320- Posts : 8
the ones I have are:
D3VE-8425
D5-9425-A3E
D6VE-9425-A3A
D9VE-????????
All are the Q-jet's? spredbore?, Is what I discovered was, ford put the EGR plate over the Q-jet ports, And turned them into the 4-hole holley. (as you stated, same stud pattern)...........
The EGR plates (that i have) are for the holley's... 2 were w/o the Egr plate Q-JET Style. Hope this makes sense.
If they had the GM style, as they used front bolts down from the top of carb. (i've never seen one)
D3VE-8425
D5-9425-A3E
D6VE-9425-A3A
D9VE-????????
Q-jet and Holley use a different bolt spacing. The ford spreadbore used the Holley
bolt pattern. Q-jet and TQ are different. The TQ will not bolt up to that manifold.
8man1320- Posts : 8
ok, I see what your looking for,
I dont have that one, i'll keep an eye out for ya. good luck!
I believe the casting number to be D4VY-9424-C.
8man1320- Posts : 8
Still looking. Let me know.
8man1320- Posts : 8
eBay --- 160764731287
GaryS- Posts : 114
Ebay.. no good.
Wrong spacing.
drbob.tqhosting.com/tech/carb/4350_compared.html
Wrong spacing.
8man1320- Posts : 8
spread bore intake cj
i have a spread bore intake cobra jet in very good shape
94429mustang- Posts : 13
It's not a big deal to fit it on.......8man1320 wrote: Torker intake uses the holley squarebore bolt pattern.
Not a big deal...please explain.
8man1320- Posts : 8
I have the stock one that came off my '68 460. If I remember correctly it had a spread bore carb on it. I will check tonight. It would probably cost quite a bit to ship.
Jess
Jess
Mustang-junky- Posts : 438
Sorry, mine is not a spread bore. Good luck with your search.
Jess
Jess
finally!!! the correct intake
Just passing this on.
eBay intake with correct spread bore
Search eBay for item # 190656998306
GaryS- Posts : 114
That intake is a CJ.
8man1320 why not just use the CJ intake? It will fit, just have to use a CJ intake gasket. Back in 1970 Ford recommended swapping the CJ/SCJ intake on to a std. port head for a 35 hp boost. Ford even used the iron SCJ intake on boat motors with D3VE heads for years, port mismatch and all. try it, you may like it...
466cj- Posts : 391
That is interesting info. I am worried that with the head ports being smaller, the flow will be all jacked up.
Maybe not???
Maybe not???
8man1320- Posts : 8
know with that big mismatch hard to believe it works, but it does just fine. Steve
466cj- Posts : 391
466cj wrote: know with that big mismatch hard to believe it works, but it does just fine. Steve
X2they work better than the small port manifolds.
8man1320 wrote: Not a big deal...please explain.
Can you drill and tap some holes? And do a little grinding?
Or if you can't just use a short adapter plate, they are available commercially. The torquer 2 manifold is much better than a stock iron one.
» WTB: Stock 1974 460 Intake Manifold Thermoquad Spreadbore Pattern
» Intake manifold design ~vs~ Intake air temp.
» Intake manifold
» Intake Manifold For 598 A-460
» intake manifold 302
» Intake manifold
