429 cam quest
429 cam quest Empty 429 cam quest
Post  cturk1010 April 14th 2012, 6:00 pm
i have a d1ve block, dove heads, stealth intake, headers stock pistons and valve size trans is a c6 with 2200 stall and running 456 gears in a cj7 jeep
run on sand only with 20 wide paddle tires
so now the big question is i called comp cam and the cam that they recomended to me is 34-239-4 that has lobe lift of .3200/.3320 gross valve lift of .554/.574 this seems to be a big cam to me for what i am running i have the heads off now and want to put new springs and do a grind on valves while i have it apart trying to keep the cost down sum (have baby on the way) will this cam work for me or is comp spot on with the best cam for me?.
.also i run race fuel 110 octain in it too but may do 92 oc rather to save 2 bucks a gallon
cturk1010
429 cam quest Empty Re: 429 cam quest
Post  69F100 April 14th 2012, 7:48 pm
You will have to have the guide cut down for that lift .540 lift is all you can with out valve guide work plus new springs.I would have Randy M , Lem or one of the others on our site make you a cam from your ride you will like it alot better than a off the shelf cam.
Post  BOSS 429 April 15th 2012, 11:24 am
cturk1010 wrote:i have a d1ve block, dove heads, stealth intake, headers stock pistons and valve size trans is a c6 with 2200 stall and running 456 gears in a cj7 jeep
110 is probaly too much for you
thats a baby cam, i'd try it
Post  cturk1010 April 15th 2012, 1:19 pm
so how much room do i need from top of seal to bottom of retainer max lift of .574+ .05 for clearance? if i am thinking right so minumum would be .624 or more
cturk1010
Post  rmcomprandy April 15th 2012, 3:38 pm
cturk1010 wrote:so how much room do i need from top of seal to bottom of retainer max lift of .574+ .05 for clearance? if i am thinking right so minumum would be .624 or more
Yea, that's about right; (very bottom of the retainer at the valve stem where the locks are).
Most seals are about ,180" thick but, they vary some.
Post  cturk1010 April 16th 2012, 4:50 pm
well the heads are done and plenty of room for bigger lift cam and now just wait for the rest of the parts and get it going again will let you know how this cam works out for me
cturk1010
Post  cturk1010 May 28th 2012, 8:06 pm
well it is done and running stronger than ever here is a vidio of it running
https://youtu.be/XbpOjv3hgq0
what do you think i am liking it so far
have another vid i will post too
cturk1010
Post  69F100 May 28th 2012, 8:44 pm
https://www.youtube.com/watch?v=XbpOjv3hgq0&feature=youtu.be
it sounds mean for sure
