new motor
new motor
looking to build a new motor. its for a class your are lemited on ci to 525 and a 4150 carb and a plate nos system and run on a 275/60/15 drag radial.what would be the best way to do a 525 big bore and short stroke or long stroke small bore.i have a set of p51 heads and the new trick flow 4500 intake going to run a spacer for the carb the car has to way 3300# and has a jet lemit on the nos system also needs to run 5.30 to 5.50 thank you for the help
bluecoupe- Posts : 26
Re: new motor
Big bore for sure. What is the limit on the NOS jet? You could do a 4.625 bore, 3.85 stroke deal and it would be 517 inches and would make a ton of power up top, and the nitrous would supplement any torque loss on the bottom. Given the limited tire I think this would be a good option for you. I figure it will take 1150-1200hp to et at that weight. Get yourself a 7531 with a power grid and you should be in business.
Re: new motor
the jet comes out to be like 210 i forgot the # sorry i can not use the 7531 or pwer grid limited to just a dig 6 and no digets or nos controllers
Re: new motor
any rules on plate type? amount of spray bars? solenoid? line sizes etc?
There are also a lot of little things a guy can do with the rest of the car to make it faster also............
This sounds a lot like a similar class we have around these parts.
Re: new motor
A 210 is huge ... A 110 is like 350 so if that is indeed the rule then your good. Can you use a cross hair plate? Your suspension will be key. Hit up Yellowhorse on here, he's real good with the small tire stuff.bluecoupe wrote:the jet comes out to be like 210 i forgot the # sorry i can not use the 7531 or pwer grid limited to just a dig 6 and no digets or nos controllers
Re: new motor
bluecoupe wrote:looking to build a new motor. its for a class your are lemited on ci to 525 and a 4150 carb and a plate nos system and run on a 275/60/15 drag radial.what would be the best way to do a 525 big bore and short stroke or long stroke small bore.i have a set of p51 heads and the new trick flow 4500 intake going to run a spacer for the carb the car has to way 3300# and has a jet lemit on the nos system also needs to run 5.30 to 5.50 thank you for the help
is there a rule on which deck height,block,or head you have to run? spacers under the carb sometimes cost power
BOSS 429- Posts : 2372
Re: new motor
its 210hp sorry.deck has to be stock and stock bore space has to be 1 nos and 1 fuel solenoid and no cross plate.
Re: new motor
So a .080 jet then or there abouts. The above combo would work fine as long as you get it to hook, might be a touch easier with A heads, but if you have P51 heads I certainly would keep them. It's gonna be a big compression deal too, and the Q if it's allowed. Big shot, or Steve Johnson plate, probly the latter.
» Motor plate or motor mounts?
» Witch Motor Would Be The Best Motor 557 0r 547 & Why ? ? ?
» 472ci For Sale
» help ID this 460 motor
» ? ON MOTOR OIL
» 472ci For Sale
» ? ON MOTOR OIL
