Need help !!!!!!!!!!!!!
Need help !!!!!!!!!!!!! Empty Need help !!!!!!!!!!!!!
Post  michealj May 28th 2012, 11:45 pm
got my combo together but having problems car went 6.0 in 1/8 on motor
started testing with spray on fogger im running a 36/28 spread and car is leaving good with 1.28 60 ft
bur thats it. Im running a progressive system leaving on 30% and delay to 1.7 in at full car has went a best
of 5.75 at 124. Its not pulling mid and upper it seems..tried changing timing no difference, plugs show no timming and
still rich..any advice..??????????????? confused confused
michealj
michealj
Need help !!!!!!!!!!!!! Empty Re: Need help !!!!!!!!!!!!!
Post  studly May 29th 2012, 12:02 am
36 nos and 28 fuel?
what base timing?
What Fuel ?
what camshaft numbers?
What is the converter doing in the gear change?
What Rear Gear?
studly
studly
Post  michealj May 29th 2012, 8:50 pm
studly wrote:36 nos and 28 fuel?
what base timing?
What Fuel ?
What Rear Gear?
base timing at28 retard to 16--c116 gas--798-785 115lb sep----500rpm drop at shift---355 rear 275 drag radial
bottle pres.950
michealj
michealj
Post  richter69 May 29th 2012, 9:20 pm
Converter sounds a Bit loose
Post  studly June 2nd 2012, 10:29 am
Converter is way off, call lenny(Ultimate Converter Concepts) and tell him you want the BBF converter he made for Studly, then you will need to readjust your ramp on your progressive. Right now you will be faster if you go back to about a 24 jet.
Stan
studly
studly
Post  Barney June 2nd 2012, 10:41 am
I agree. Tighten her up.
Barney
Barney
