NOS Plate ?
1970 ford maverick
colormebad
NOS Plate ? Empty NOS Plate ?
Post  colormebad June 10th 2012, 12:48 pm
Have a friend thats trying to find out if he has a preset nos plate or what..Its a thin black nos plate with 17 holes.. 34 total....Noids listed below...
NOS 16045 Nitrous Solenoid > ProShot
NOS 16050 Fuel Solenoid > Cheater
colormebad
NOS Plate ? Empty Re: NOS Plate ?
Post  1970 ford maverick June 10th 2012, 3:34 pm
colormebad wrote:Have a friend thats trying to find out if he has a preset nos plate or what..Its a thin black nos plate with 17 holes.. 34 total....Noids listed below...
Sounds like a "Cheater"plate to me,just a guess though,look at the jet setting,if the nos jet is higher than the fuel?, then it is the upto date plate.Hope this helps ,MAVMAN
1970 ford maverick
1970 ford maverick
Post  colormebad June 10th 2012, 4:58 pm
I have always ran other brands besides nos , so i dont much about the nos stuff..
It has a 82 Nos and 73 Fuel in it now..That shows to be like a 175 or 180 shot
colormebad
Post  1970 ford maverick June 10th 2012, 7:06 pm
Yes,or more COLORMEBAD,that would be one of the newer kits,its a good plate,I would start with a smaller hit. Go to the NOS sight and get the new settings,your friend and power plant will be happy.Spray Away Bro,"MAVMAN"
Last edited by 1970 ford maverick on June 10th 2012, 7:16 pm; edited 2 times in total (Reason for editing : error)
1970 ford maverick
1970 ford maverick
Post  Barney June 10th 2012, 7:53 pm
That's about 225 on a big shot plate. Start around 5.5 Fp,and let it eat.
Barney
Barney
Post  PangleRacing June 29th 2012, 11:21 am
Barney wrote:That's about 225 on a big shot plate. Start around 5.5 Fp,and let it eat.
Agreed... 82n 73f is a 225hp tune-up.
PangleRacing
Post  bruno June 29th 2012, 11:23 am
just curious how much timing are you pulling out for a 82 jet ?
http://WWW.CKRME.COM
Post  PangleRacing June 29th 2012, 11:39 am
Well every setup is different... But we have Dana's 514 (CobraJet crate motor w/SCJ heads) with 34 of total timing on the motor, and pull out 14 degrees on the 82/73 tune up (NOS BigShot plate 4150). Our timing tune-up is super conservative, our heat mark is super low on the ground strap probably due to the 9.5:1 compression and big dished pistons-just a guess though-I'm no nitrous guru!!!
We leave on about 15% of that 225 and ramp the rest in over .5 secs and the car is on the edge of smoking the tires (28x10.5stiffs) on that pussy cat tune-up!!!
3000lb True S/S '86 Coupe, PG w/1.80 low gear, and a 4.10 out back...
PangleRacing
Post  4604X4 July 4th 2012, 6:41 am
Not to highjack this thread - but what is the "preset nos plate"?
I have the NOS p/n 12500 (installed in '93). Did NOS change plate designs along the way? I haven't kept up with this stuff.
Is the jetting chart on NOS' site wrong/different for my old plate?
4604X4
4604X4
Post  1970 ford maverick July 4th 2012, 9:40 am
"4604x4" The new settings are alot more aggressive,say back in the day '93,a 225 shot was 82n 91f,real fat,new settings are more like 82n 73f alot more powerful.The plate you have will work fine with the new settings,Hope this helps you,MAVMAN
1970 ford maverick
1970 ford maverick
