How important is bottle pressure?
How important is bottle pressure? Empty How important is bottle pressure?
Post  4604X4 July 6th 2012, 1:57 pm
As I use up the N2O and bottle pressure drops - can anything bad happen to my motor? In other words, can I keep spraying until I run out of N2O or do I need to stop and refill the bottle when pressure drops to some number (say 500psi). Will it just start running rich with no harm done? Fuel pressure should stay constant and jets aren't going to change so as pressure drops I guess it justs to run richer and richer.
This is a street engine with up to a 150HP spray on a plate system. There is a N2O pressure gauge on my dash pod.
Will a bottle heater keep the pressure consistant (say at 900psi) until I run out of N20? Is that purpose of the heater?
4604X4
4604X4
How important is bottle pressure? Empty Re: How important is bottle pressure?
Post  whatbumper July 6th 2012, 2:44 pm
Remember that pressure is not directly proportional to content remaining.
Post  richter69 July 6th 2012, 3:22 pm
Pressure affects the tune up, it is very important IMO. I try to shoot for around 950psi before I stage, its usually at or above 900psi after the run. Dont leave the pressure on the solenoid any longer than possible. I dont fill my bottles all the way up, I usually only go 9 lbs........seems to make the pressure not fall off as bad as one thats at full or over capacity. I dont use a lot but after 3-4 passes I put a fresh bottle in.
A side note you'll never get all the nos out before it flashes to vapor inside the bottle..............in other words a 25# bottle you wont get usable nos at 15.5#s, usually somewhere in the 18-19 # total weight the liquid is no more.....................
Post  Induction-Solutions July 9th 2012, 3:04 pm
Pressure and volume are important. You want to maintain a consistent pressure at the start of each run. The volume of liquid in the bottle will in part dictate the pressure drop you'll see during the run as the bottle relies on this liquid to boil and help regenerate vapor pressure during the run. From what I commonly see once you take about 50-60% of the liquid out of the bottle, you'll see larger pressure drops.. Hope this helps.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
