598" ;) A head - Dyno results page 6
+38
larry552
nitrous.f
butterbean
Larry Williams
Barney
yellowhorse7
psfracer
70FB
67mustang
popskull
67460
Copperhead
2POWERADDERS
Wheelie58
dirt_worker
tconnection
QtrWarrior
Oakley Motorsports
1970 ford maverick
dtimmer
v-twin
kjett
AZFairlane
badsnake306
soupbean
42 posters
Page 2 of 8
Page 2 of 8 • 1, 2, 3, 4, 5, 6, 7, 8
Re: 598" ;) A head - Dyno results page 6
AZFairlane wrote:soupbean wrote:Charlie Peppers wrapped up the machining and balancing yesterday. My wife had surgery today so beginning assembly may have to wait until next week. Hopefully we will be bolting her to the dyno by the end of this month and testing in the car early August Cant friggin wait!!!
Your Wife?
I knew that was coming LOL. She gets bolted to the soupbean dyno regularly! Got some hellacious torque!!!
soupbean- Posts : 637
dfree383 wrote:Early aug? Hell man that's a year away!
What ever that month is that comes after September
Bolted on, that's serious. I always just use a non-splined slip coupling.
AZFairlane- BBF CONTRIBUTOR
soupbean wrote:AZFairlane wrote:soupbean wrote:Charlie Peppers wrapped up the machining and balancing yesterday. My wife had surgery today so beginning assembly may have to wait until next week. Hopefully we will be bolting her to the dyno by the end of this month and testing in the car early August Cant friggin wait!!!
Your Wife?
4.5" of stroke with a 6.7" rod is fairly large right???
AZFairlane wrote:Bolted on, that's serious. I always just use a non-splined slip coupling.
When you get over 7000 rpm, you better be bolted on, otherwise alot of damage could occur with a slip coupling
I haven't been able to get any where near 7000 rpm for years now.
AZFairlane wrote:I haven't been able to get any where near 7000 rpm for years now.
They have Pills for that....
Sounds like he needs a timing adjustment to get them rpm's back.
kjett- Posts : 1169
Better keep her around 68 when she hits 69 she will blow a rod................
IDT-572 wrote:Better keep her around 68 when she hits 69 she will blow a rod................
Or a seal
Might need to get an upgraded cam shaft while he's at it...
kjett- Posts : 1169
and make sure the pump has enough pressure.........
does charlie peppers have a dyno? Is he still close to winder ,Ga nice build
v-twin- Posts : 52
v-twin wrote:does charlie peppers have a dyno? Is he still close to winder ,Ga nice build
Yes and yes.
dtimmer wrote:any updates?
Not alot. Got tied up with work and finishing up the race season. All machining is done, and most all parts are here. The heads and intake will hopefully be back some time next week. I'm hoping to be on the dyno in 2 weeks or so at this point.
Mains were a little tight so took the mains to the high side.
Oh and Santa Lem dropped off another present last week. Very nice pieces!
put a little glue on the front of the cam or it'll leak oil out the pin holes and get on the top pulley and belt. dont get the belt too tight,it'll let you know if you do.............
Put a little silicone in the cam snout and cam pin holes...before install and life will be good.
i heard that somewhere.....Lem Evans wrote:Put a little silicone in the cam snout and cam pin holes...before install and life will be good.
Well, broke the crankshaft on the back up 514 last night at the divisionals. I guess racing will no longer slow the process of getting this motor together
bad way to end the year.soupbean wrote:Well, broke the crankshaft on the back up 514 last night at the divisionals. I guess racing will no longer slow the process of getting this motor together
» Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
» 598 A head w dyno results
» 582 tfs a460
» 533 Dyno Results
» 598 C heads
» 582 tfs a460
» 533 Dyno Results
» 598 C heads
Page 2 of 8
