545 carb to pan
545 carb to pan
I have the car Nitro Lew built. I just bought a 9.5 deck all aluminum small block so I'm selling the 545 thats in the car now. To the best of my knowledge this is what is in the engine and trans.
545" all forged bottom end 14.5 compression
Evens Racing Engines Trick Flow Street heads
1150 Dom
somewhere around .780 lift cam
Was told it was built to make around 800-900 hp
has a C6 trans bolted up to it that is built as well with a 3500 stall.
Engine has never been fired and trans never driven on.
13,500 Carb to pan and trans
1150 Dom
LBSRACING- Posts : 32
how much
maybe i missed the price some where, and is it fresh if not what where the performance specs
1fatcat- Posts : 44
Re: 545 carb to pan
1150 Dom
Gee I guess the pictures got ya ....
1150 Dom
Re: 545 carb to pan
1fatcat wrote:maybe i missed the price some where, and is it fresh if not what where the performance specs
Engine and trans has never been run. 13,500 obo for both.
Thanks Burt
Re: 545 carb to pan
Guys this my motor and everything is 100% new !! Here are the specs.
30 over Dove block with a machine work and everything is studded
Scat forged 545 crank/ internally balance ...lot of money send there!
Scat h-beam rods
Probe pistons I think the compression was around 14.1
Charlie Even custom solid roller forgot the specs / comp cam solid roller lifters
ATI damper
TFS Street ported by Charlie Evens
Victor intake ported to match the heads
Custom Pro Systems Dominator
The c6 I bought from someone on this site . Its a full build c6 with a trans break. the converter is a 3500 stall however behind this motor Im sure it will stall more!! This is a mad ass motor guys !! If I didnt just buy a turbo notch I would be buying it back !!!!!
Scat h-beam rods
ATI damper
Nitro Lew- Posts : 78
Re: 545 carb to pan
Hey thanks for the update there Lew. Good luck with that turbo. I may have to come up that way when I get my Procharged engine together
» weiand carb adapter 4500 carb flange to 4150 intake
» QF 1050 dominator
» 780 carb
» Carb help
» Problem with car racing
» QF 1050 dominator
» 780 carb
» Carb help
