Converter Question ?
whitefield
Page 2 of 2 Previous  1, 2
Converter  Question ? - Page 2 Empty Re: Converter Question ?
Post  richter69 September 9th 2012, 10:32 pm
only about 23 years, I aint as old as most of yall........ bom
Post  ultimatelenny September 10th 2012, 8:22 am
richter69 wrote:id think a 9" in the 5200-5500 range would work.
X2. I would suggest our S98 type 9". As opposed to the 9.5 converter, this piece will hold close to 5 qts of fluid while using an 8" stator assem for stall management and stall variation, while being very efficient as well as having great street manners.
ultimatelenny
ultimatelenny
http://www.ultimateconverter.com
Post  DILLIGASDAVE September 11th 2012, 4:44 am
If someone had missed the "correct" converter combo what would hurt a car less? (A) converter too tight with a steeper rear gear as a crutch, or (B) converter too loose with less rear gear as a crutch.
Post  ultimatelenny September 11th 2012, 8:15 am
DILLIGASDAVE wrote:If someone had missed the "correct" converter combo what would hurt a car less? (A) converter too tight with a steeper rear gear as a crutch, or (B) converter too loose with less rear gear as a crutch.
Tough question, lots of variables. I think if we are talking big block, big torque with limited RPM, I believe, with data i have seen, missing it tight with with more gear is the better of the two crutch wise, torque conquers a lot of small variables. If you are dealing with a small block application, whose torque numbers are a lot higher and tends to like spinning a lot higher and does not like to be tugged on, the looser route has more of an advantage. Again, you have to consider all the variables in any given combo. Hope this helps a little.
ultimatelenny
ultimatelenny
Post  DILLIGASDAVE September 14th 2012, 9:47 am
ultimatelenny wrote:.........Hope this helps a little.
Thanks. Cool
I guess if someone misses too tight, more power can always be added as a crutch too. Add more power if it's too loose & driving through the converter is always a possibility.
Post  ultimatelenny September 14th 2012, 10:22 am
Thanks. Cool
Correct
ultimatelenny
ultimatelenny
