new from florida
new from florida
hi my name is james i'm building a bogg truck 74f100 coil springs and triaulated 4 link with a 460 out of 1969 lincoln chassie fab is done fixing to pull engine back out to start engine build got a set of seal power flat tops lw-2602f-30 heads are c9ve-a block is c9ve-b going to use comp cams magnum 280 h what do you guys think hp rating will be thanks
74f100- Posts : 28
New From FL.
Hellow 74f100,Im just up the road from you here in J-ville,Lots of good "Ford Blue"blood flowin on this site.From the details of your build,looks like your headed in the lines of 370 to 470hp range James, and im no pro,thats just a guess.Big intake and carb,lots of head work and that will up the HP more,im sure others will chime in to help you with your build. MavMan
1970 ford maverick- Posts : 180
Re: new from florida
Welcome aboard James!!
61coon- Posts : 1824
Welcome James,
If your cam hasn't been bought yet, rethink what your putting in it. The 280h is a single pattern cam and at that size you need 6 degrees of split or more. The XE274H is in the same ball park and will make good power.
Keep us posted...............
hey thanks blake i was also looking at a lunati 11602 kit it has more split and will be less money is the
XE274H made by comp
XE274H made by comp
74f100- Posts : 28
Yes that cam is from comp. And worth the difference.
welcome !!!
5pointslow- Posts : 1408
» Hello from SW Florida
» New guy from Florida!
» Hello from florida
» Hello from Florida.
» New from Florida
» New from Florida
