Chuckathon: Help Chuck get back onto the Dragstrip
+41
blown473
gdog
bigblockfox468
Gary Varney
lghting94
72mav
Bsherry
56Tbird
bluef100fe
racerk_2000
KY JELLY
knrclark
Yoeman
90hatch460
Paxton Dan
ThndrChkn
chuck hockenberry
Dave Maxwell
342g
QtrWarrior
Lonewolf1970
John I.
David Willingham
the1969fordguyinky
D. Sea
45 posters
Page 6 of 7
Page 6 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: Chuckathon: Help Chuck get back onto the Dragstrip
I know Coug ,I've sat in it too...kinda lets you know how Les & Gerry feel when they go anywhere and have to get a Booster seat
56Tbird- BBF CONTRIBUTOR
yeah just think if they sat in his car the would just barely get their feet hanging over the edge and have 3 ft to the peddles...... take a big block of wood for them to reach it.......
the Coug- Posts : 3055
More like a set of stilts
Coug you and Dan need to stop picking on the handicap. At the NMRA race in BG Dan got in my car and it looked like a little kid about 4 years old setting in there.Someone oiled down the track and Dan took a nap in my car.Now for new update me and Damon went down to Bill's house today to help him sit the new body over on the frame.I am very happy how everything fit on the frame.There is a couple of places Bill said that needs to be trimmed up too make the body fit the way he wants.But all in all everything looks great.Damon and Bill both took pictures of everything and should be up on here in the next couple of days.I can't wait too see it done.Its going to turn alot of peoples heads.Thanks again Bill and everyone that has helped out.I can't say it enough.You guys are GREAT!!
Lonewolf1970- Posts : 355
Can't wait to see it Chuck. Is it going to sit low? I looked for a fuel cell at Columbus but all I seen was a 10 gal. and he thought it was lined w/gold.
Are you going to use headers that run inside or outside the frame? LiL Tweety's run outside and it opens up alot of room for oil pan removal,starter,header removal,and the use of a engine diaper. And lastly what parts do you still need? Glad it's coming together
Rick,
I need to update the list again however not much has changed since the last update as far as parts. WE really need the fuel cell or at least the measurements so I may have to go ahead and buy one. We need a 5 gallon aluminum cell. Chuck and Bill were talking about an aluminum fuel cell from ART? I haven't looked into it yet.
I haven't downloaded my pictures yet but looks like Bill has. I'll list them on the build thread
https://www.429-460.com/proven-builds-f4/chuck-s-1970-mustang-the-rebuild-t1653.htm
D. Sea- Posts : 2768
I personally like a Alum. fuel cell over plastic and foam. But thats just me.
Chuck,
Santa Brandon sent a present to you. It's under the Christmas Tree
Santa Fabio is sending you another Present that should be here shortly
Merry Christmas Big Guy!
Santa Fabio's gift arrived Friday.
Merry Christmas Chuck, it's at the house anytime you are in the neighborhood
On a side note; Suzzane, Chuck's sister, says she likes gifts too
Well..................
Damon or Chuck can ether of you post some pics of the header collectors that blowen473 gave you I would like to see how the evac is welded in it.I need to weld one in my headers just want to make sure I am on the right track.
Thanks Jim
Thanks Jim
Not the same collectors but very similar, here's a few pictures of mine when I first put it together.
Thanks Damon that is what I was thinking would it be to much trouble to see what degree it is set at and post it it looks to be aroung 45* it is sitting just want it to pull good.
Thanks Jim
Thanks Jim
Yep, they are cut at a 45 degree angle for welding into your collectors. Best place to place them is on top however that's just not possible in a Fox Body
Damon
I am to lasy to read all the posts, is there a list of what Chuck will need to finish up?
IDT-572 wrote:Damon
Too much to list, I'll have to update it but here's what I have on the excel file
1 Strut type front suspension
2 Shifter Cable
3 Fuel Cell: 5 or 8 gallon Brandon Reid
4 Fuel Pressure Gage
5 Oil Pressure Accumulator & Solenoid
6 Drag Chute, release cable and handle M. Stevens donated a chute
7 Crank Case Evac System
8 Window Net
9 Two Batteries: Optima type
10 Safety Belts:
11 Oil pan & Pickup: Rear sump
12 Trans cooler: stacked w/fan & thermostat
13 Glide tail shaft housing and possibly the case. Coug
14 Wheelie Bars Steve Neville "Nevs"
15 Push-Pull On/Off battery disconnect Travis Rice
16 Header flanges - TFS Streets & 2 1/8 - 2 1/4 tubing plus collectors to make custom headers Charlie Evans
17 Fan(s) for radiator: First we need to measure radiator sent by Rick Brown
13-Nov
18 Rack and Pinion
19 Coil Over Rear Shocks
20 Wheels Front Wheels: Jon Faubion
21 Slicks 32 X 14
22 Engine Plate - Front: D. Willingham?
23 4-Link Brackets
24 3/4" LH Tap
25 Master Cylinder
26 Rear Brake Caliper Brackets - Need to get a drawing
D. Sea wrote:IDT-572 wrote:Damon
2 Shifter Cable
8 Window Net
10 Safety Belts:
13-Nov
18 Rack and Pinion
21 Slicks 32 X 14
23 4-Link Brackets
24 3/4" LH Tap
25 Master Cylinder
Damon,
I can fix you up with a fuel pressure gauge as well. I've got an Autometer Sport Comp with the isolator and the hoses, etc. I'll bring it to the tech seminar if you want it. Let me know.
Nevs- BBF CONTRIBUTOR
Sure thing, bring it and if we can't use it, I'll send it back. That goes for all donations
Thanks guys!
Thanks guys!
crank case evac
Do you still need one, I think I have a a new one out in the shop some where, PM me if you do and I,ll look it up. Ward
Thanks Damon for the info on the evac tube mine will have to be in the side as they are tucked tight under the cab for ground clearance
Jim
Jim
dr's wife racing wrote:Do you still need one, I think I have a a new one out in the shop some where, PM me if you do and I,ll look it up. Ward
Ward,
Need one?
Are you guys (you and Cole) going to the tech seminar?
any updates yet
Snow........
Chuck said he's going to drop the rear out of the old car tomorrow.
Just happened across this and figured i would ask if you guys are still taking donations?
I dont have much but i doubt i will be on the track anytime soon so maybe some of my money can go elsewhere to someone that can put it to use soon.
Maddmattmustangs wrote:Just happened across this and figured i would ask if you guys are still taking donations?
Always and thanks to you and EVERYONE involved
I'll shoot you a PM
» chuckathon fund raiser
» Met bigblockfox468 at the dragstrip!
» What to bring to the dragstrip?
» Dragstrip teching
» Lem
» Dragstrip teching
» Lem
Page 6 of 7
