Timing
Timing
I have a MSD Pro-Billet Small Diameter
Street Ford V8 Distributor PN 8477; 351C-460, PN 8478; 351W PN 8479; 289/302
On my semi new 79 460 with a c6 trans & 525hp 500 torq in my 64 f100
What should my timing be to achieve peak performance???
Any suggestions?
Here are some specs:
do know that it is .30 over flat pistons, stock crank, dove c heads, mighty demon carb and comp cam roller rockers.
I hope someone can help!
Any suggestions?
Tigger!- Posts : 16
Re: Timing
Need lots more info. Cam spec's,what heads ? what comp.ratio? etc.
Re: Timing
Right around 32* seems to work best with the factory cast iron heads in most cases. Track times, or a dyno session are the only ways to make sure.
schmitty- Posts : 4538
