What octane for 14:1cr
Bret Powell
2fox
tconnection
What octane for 14:1cr Empty What octane for 14:1cr
Post  tconnection January 22nd 2013, 12:45 am
Which fuel or octane for 14:1cr?
tconnection
What octane for 14:1cr Empty Re: What octane for 14:1cr
Post  dfree383 January 22nd 2013, 1:05 am
Here's some guidelines from VP, but alot depends on your application.
http://www.vpracingfuels.com/vp-drag-racing.html
Post  2fox January 22nd 2013, 2:03 am
VP C-16 117 octane .I would think? Subbing
2fox
Post  bbf-falcon January 22nd 2013, 5:54 am
112 always woeks good for me.
Post  Bret Powell January 22nd 2013, 9:59 am
Depends some on the form of racing and whether you have iron or aluminum heads. It is not quite as simple as compression.
Bret
Bret Powell
Post  rmcomprandy January 22nd 2013, 10:57 am
Bret Powell wrote:Depends some on the form of racing and whether you have iron or aluminum heads. It is not quite as simple as compression.
Bret
X2 ... there are several fuel octanes which will work with that compression ratio. It is a matter of what YOU want from your fuel.
With 14/1 compression ratio...
C12 works well if it is not stale
C25 will make more power at almost twice the cost
I like "Late Model Plus" because it stores and travels well over long periods of time without changing.
Then there are the oxygenate fuels.
VP113 is probably the best bang for the buck but, again
Q16 will make more power at about twice the cost.
AND, then there are all the other brands of comparable quality.
I have one customer who swears by the "Powermist". Then Renegade and a bunch of other brands.
As said ... octane is NOT the only spec to look at.
Post  tconnection January 22nd 2013, 11:47 pm
Drag race only,aheaded 580ci. What you all run?
tconnection
Post  rmcomprandy January 23rd 2013, 12:18 am
tconnection wrote:Drag race only,aheaded 580ci. What would run?
How often you intend to buy fresh fuel will go a long way to determining what you run ... Personally, as said, I would use VP Late Model Plus.
Post  tconnection January 23rd 2013, 12:38 am
I ment to say, what you all run, but ok. Thanks for all the info.
tconnection
Post  2fox January 23rd 2013, 1:08 am
Nitromethane?
2fox
Post  dfree383 January 23rd 2013, 4:09 am
Q16 is my choice fuel, but its expensive.
Post  2fox January 23rd 2013, 7:02 am
dfree383 wrote:Q16 is my choice fuel, but its expensive.
is that fuel.great for.nitrous too? Buddy?
2fox
Post  dfree383 January 23rd 2013, 7:12 am
I haven't use it with it, Might get some answers from some of the NO2 guys here.
Post  rmcomprandy January 23rd 2013, 11:01 am
tconnection wrote:I ment to say, what you all run, but ok. Thanks for all the info.
I don't own a race car however, I buy fuel by the 55 gallon drum to be used on the dyno throughout the year and that drum lasts about 6 or 7 months.
Post  rmcomprandy January 23rd 2013, 11:07 am
tconnection wrote:Drag race only,aheaded 580ci. What you all run?
Now your rules change to using nitrous so, to get a half way decent educated answer I think you should let it be known how you intend to use this gasoline, what you expect from it and the entire combination of what vehicle and engine it will be used in.
If you are after a specific answer, (instead of what will work), then you should ask the question specifically.
Post  jbozzelle January 23rd 2013, 11:30 am
Sunoco Supreme here. Mine and friends SBC deal all seemed to do OK on it. $9.50 - $10 bucks a gallon...
Just noticed there is a Shell race fuels dealer near where I work. Going to have to check out what they have.
Post  richter69 January 23rd 2013, 2:25 pm
imo it works great if your running a jet restricted class, the t/u window is narrower, gotta be on your game if your spraying with it. Also if you have a very good combustion chamber you have to really pull a lot of timing out.
Post  yellowhorse7 January 23rd 2013, 11:12 pm
Narrower is an understatment. 3 SETS of HG's until I figured it out, lol. And my game was good!
yellowhorse7
yellowhorse7
Post  tconnection January 23rd 2013, 11:45 pm
No my rules remain the same, N/A. I don't like nos. To much like a bad woman. The vp late model plus sounds good.
tconnection
Post  2fox January 24th 2013, 9:29 pm
that's what I been running with nitrous. Cause I thought more octane was better.unless someone can. Give some ideas on what to run.but I got to many specs to list.
A lot of people.are going E 85 on llike 03/04 Cobras.they say it's better than C16 cause of the cooling effect?
I got a 2003 Cobra Vert.
2fox
