Hypothetically ???
jones
Hypothetically ??? Empty Hypothetically ???
Post  bruno October 12th 2009, 3:23 pm
So if im running 5.70 's on the first kit --- How much spray will i need to run 5.30's on the fogger ???
http://WWW.CKRME.COM
Hypothetically ??? Empty Re: Hypothetically ???
Post  jones October 12th 2009, 3:28 pm
Wow, did you just really do that? LOL
I would suspect they would atleast need to know how big your first hit is. To atleast give some type of referance point.
jones
Post  bruno October 12th 2009, 3:58 pm
so if i ran that # on motor compared to running that # on a 73/63 tune ...would be different ????
Post  Induction-Solutions October 12th 2009, 10:59 pm
What does the car weigh ?? SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  bruno October 13th 2009, 8:04 am
3200 with driver
Post  KY JELLY October 13th 2009, 8:55 am
A friend of mine that runs with us in the dds is spraying 500 on a 434 sbc it runs 5.40 without and high 4.80's - 4.90's with the only problem is it will only last about 6-8 passes and it lifts the rings Shocked it was living fine on a 400 shot though.
KY JELLY
KY JELLY
Post  Induction-Solutions October 13th 2009, 9:10 am
I'll bet it's tough to say for sure ?? At 3200 pounds the converter is going to play a good part in what it takes to pick up that much ?? My guess would be it will take between 250-350 HP ??? SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bruno October 13th 2009, 3:22 pm
ok so then i guess the next thing i need is a tune for my fogger ......... the plates is at a 73/63 @ 5.5 lbs of fuel timing is at 26 ... were should i start my tune for the fogger ???
Post  Induction-Solutions October 13th 2009, 7:36 pm
250 to 350 !!! Very Happy SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bruno October 14th 2009, 6:32 am
Induction-Solutions wrote:250 to 350 !!! Very Happy SJ
cool ....... so what jets and timing should i start out at ?
and here is my build
562"
13.2-1 comp.
Ford SVO A460 Block
Diamond Flat top Pistons
R and R connecting rods Billet aluminum
4.3 RPM Forged Crank
Heavy NOS ring package
Cometic Gaskets
Danny Bee
Edelbrock Victor Intake Ported w/ pro sportsman fogger
Edelbrock Rpm Performer cnc heads --reworked By Charlie Evans
Intakes; .100=71.5, .200=157.4, .300=241.1, .400=289.3, .500=321.4, .600=349.4, .700=369.3, .800=384.1 cfm.
Exhausts; .100=55.8, .200=110.6, .300=151.8, .400=191, .500=217, .600=233.1, .700=238.1, .800=238.4 cfm.
Custom Cam by Lem Evans ( cam guru )
Trick Flow push rods
Manley nextek spring package
Yella Terra roller rockers
Innovate West Dampner
Quick Fuel 1250
Jomar Power cone w/ a NOS big shot plate
base timing is at 32* and 26* for the plate tune im going to kick the digiset to spray the fogger at 4-tenths out
Post  Induction-Solutions October 16th 2009, 12:01 am
If you want, give me a call this next week and we'll do some figuring on all this.. I'm in Memphis for the weekend and I'll be back at the shop Monday afternoon.. SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bruno October 19th 2009, 9:13 am
I will Steve ..... took the car to the track yesterday and now that i got the throttle fixed that tune is spot on !!!! i just need to get the suspension to settle down Laughing
here is the 2nd pass with the plate 73/63 @ 5.5 @ 25* 9.08 @ 160
Hypothetically ??? Th_053
Post  Induction-Solutions October 19th 2009, 10:29 pm
That things makin some beans bro !!! Nice peddle job and the 160 MPH show's it has a little power !! Shocked Looks to me if you settle the front down on the leave it will run @ 8.6-7 pretty easy... SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  4thHorseman October 20th 2009, 9:57 pm
"here is the 2nd pass with the plate 73/63 @ 5.5 @ 25*"
Don't want to hijack. Just interested in clarification. That's a 73N/63F jet setup in your NBS plate for your 1st stage? If so, I must be running my tune fatter than I expected. ???
I have it backwards right?
I'm running 85N/91F @ 6.5psi 28 degrees timing and ramping it in from 55% to full over a 1.5 seconds spread.
Shaving a second and adding 12mph to my na 1/4 et.
I'm running corrected 9.6@141mph with that tune on my junk.
4thHorseman
4thHorseman
Post  studly October 28th 2009, 7:42 pm
never run more fuel than nos, that is bad mojo
studly
studly
Post  4thHorseman October 28th 2009, 8:34 pm
Really?
All the NOS jetting charts which I begin tuning with for the plate kits are bigger on the fuel jet at 5.5psi. I realize they are fat for safety reasons and I usually end up dropping the fuel jet a few sizes and get a nice looking plug. Never tried evening them out or going smaller than the nos jet with the fuel one on the plate. I will have to test this out. Carefully... study
4thHorseman
4thHorseman
Post  studly October 28th 2009, 9:28 pm
I learned by spending money do not run the nos tunes or the motor rich, most failures are caused by lifted ringlands in nos motors( i lifted 8 ) this is due to fuel getting by the rings then igniting the leaner(more fuel you can burn) the less chance of this happening. I run an 8 jet spread 8 more nos than fuel and have not hurt any parts this year and won the 5.95 championship for King of the streets.org. I read alot on Steves forum on YB and Monte Smith after trashing 8 pistons and so far i have had good luck. the main thing is pull timing read plugs and keep adjusting until you have your specific tune for your motor. when you pull a plug in my motor at the end of a pass it looks like new.
studly
studly
Post  4thHorseman October 28th 2009, 10:55 pm
My interest was peaked earlier about your comment.
I've been on YB on the nitrous forum for about an hour now and I am enlightened. sunny
I was pretty happy with my run on an 85n/91f tune using a progressive. The more I read the more I realize how jacked up that factory-type tune is. Ha!
At 6psi fuel pressure, how does something like an 85n/78f tune up sound for a 225hp progressive hit?
4thHorseman
4thHorseman
Post  bruno October 29th 2009, 9:05 am
4thHorseman wrote:"here is the 2nd pass with the plate 73/63 @ 5.5 @ 25*"
yes that is correct ........... you need to call Steve and run your combo over with him and he can get you a baseline tune .....always ck your plugs Wink
Post  studly October 29th 2009, 10:22 am
i think a true 225 hit will probbaly be a 91 nos jet and 85 fuel jet at about 5.5, but bruno is right call Steve he have been doing this stuff alot longer than most, i am getting ready to send my victor 460 intake for a fogger install, the speedtech plate i have is alright but a fogger is the good mojo.
studly
studly
Post  bruno September 8th 2010, 6:59 am
4thHorseman wrote:My interest was peaked earlier about your comment.
any updates with your car??
