Keith Fulp's 618 A Head Interceptor
+32
ProStreetFairlane
butterbean
514F-1
White Lightning
dr's wife racing
crittersf1
badnotch
Oakley Motorsports
ts9201dean
Outlaw5.0
67460
sharxdesign
PanaVet
66prostreetfairlane
yellowhorse7
psfracer
4speed
NOS42
soupbean
61coon
Wheelie58
36 posters
Page 3 of 4 Previous  1, 2, 3, 4  Next
Keith Fulp's 618 A Head Interceptor - Page 3 Empty Re: Keith Fulp's 618 A Head Interceptor
Post  Wheelie58 July 18th 2014, 6:58 pm
Quick estimate....$30 to $35,000.
Depending on fuel system options.
Thanks !
Keith
Wheelie58
Wheelie58
Post  Mike R July 18th 2014, 7:22 pm
I'll take two Laughing Laughing Laughing
Post  514F-1 July 18th 2014, 7:43 pm
Thanks Keith, thats abut what I was thinking. Wish I could afford one Sad  What do you think it would run in a car that's lighter, like a 2400# Top Sportsman Type Car?
514F-1
514F-1
Post  Wheelie58 July 18th 2014, 8:26 pm
Well...
At 3850# with a soft tune, it ran 8.94 a few weeks ago at Bowling Green.
You can do the math, subtracting 1450#, but it should run in the 7s NA.
It is approaching 200 runs, but still seems fine.
This coming week, I will "break the seal" and pull the lifters out for inspection.
It is my first set of bushing type lifters, and I just want to look at them.
Wheelie58
Wheelie58
Post  Dave De July 19th 2014, 11:34 am
Amazing having that much power and reliability. Dont you want to get another race car and swap the engine into it for a few all motor heads up events? When you're done you can still put it back in the 58.
Thanks for sharing the testing.
Post  Wheelie58 July 20th 2014, 8:53 am
Dave
Another car is in the thinking stages. I met with Richard Earle about a T/S 58 Ford (made from his 7/8 scale 57 mold.)
The 618 is planned to stay in the 58 until the "Interceptor Lite" 638 is finished.
It will be similar to this engine but will have an aluminum block, smaller bore and 1/2" more stroke..more cam(?)
Thanks !
Keith
Wheelie58
Wheelie58
Post  Wheelie58 October 20th 2014, 8:16 am
Update....
The 618 now has over 250 runs. Third set of spark plugs. No issues since replacing the pushrods due to top ball wear at 200 passes and a broken intake rocker at about 200 runs.
I still want to pull the lifters for inspection before 2015 racing, since they are my first "bushing" bearing set.
Runs good enough to compete in Super Comp 8.90 last weekend at 3920# and a tad of retard.
Keith
Wheelie58
Wheelie58
Post  FalconEh December 21st 2014, 8:06 pm
Bump ...for a review of an Awesome build Cool cheers
Post  butterbean December 22nd 2014, 12:14 am
bump for lifter inspection???
butterbean
butterbean
Post  Wheelie58 December 22nd 2014, 12:26 am
I never got around to inspecting the lifters...
Yet.
The lash is staying constant, so I am not super worried, just curious.
As soon as I get around to it, I will post in this thread.
Thanks !
Keith
Wheelie58
Wheelie58
Post  68formalGT December 24th 2014, 2:11 am
Keith, would these work good with nitrous?
Post  Wheelie58 December 24th 2014, 4:40 am
68formalGT wrote:Keith, would these work good with nitrous?
The thick deck and 18 bolt pattern of the Trick Flow casting combined with a huge port area, would make a fine nitrous head. I would add a softening "dish" CNC cut to the quench area if desired by the customer.
Thanks,
Keith
Wheelie58
Wheelie58
Post  ProStreetFairlane December 27th 2014, 1:30 pm
Awesome build Twisted Evil
ProStreetFairlane
ProStreetFairlane
Post  68formalGT January 25th 2015, 9:34 am
Wheelie58 wrote:During this year, I am going to do a set of a more conservative spec and put those on a 598-605 for a test.
I also will "twist" a single 4 manifold.
Thanks,
Keith
Keith have you put together any other builds like mentioned above?
Post  Wheelie58 January 25th 2015, 10:04 pm
Thanks,
Keith
I have not personally done any 10 liter single carb Interceptor work (yet).
Engine Systems has a couple of Big Bore - short stroke Interceptor engines that dynoed nicely with single gasoline carbs. One engine was about 515" and the other in the mid 540" range. Both used Interceptor heads and Trick Flow cast single 4 intakes with major port and plenum work.
Both were high end builds with big cams. Both made 1100 HP (+-) and pulled strong in higher RPMs.
Thanks!
Keith
Wheelie58
Wheelie58
Post  PanaVet January 25th 2015, 11:28 pm
I'm sure you looked at your lifters by now. How's everything looking?
PanaVet
PanaVet
Post  68formalGT January 26th 2015, 2:17 am
Pretty darn good numbers Keith, 1100 horse at 500-550 cubes, awesome!!
Post  Wheelie58 January 26th 2015, 3:00 am
PanaVet wrote:I'm sure you looked at your lifters by now. How's everything looking?
PanaVet
I regret to report that I have not touched the car or engine since the last race of 2014. I will check it over in early February, before the first race in Orlando.
Just too much to do....
Keith
Wheelie58
Wheelie58
Keith Fulp's 618 A Head Interceptor - Page 3 Empty Orlando race
Post  STR-LGL-70 January 26th 2015, 12:33 pm
Keith,
Can you post the dates for the Orlando race? Since I'm currently only spectating I'd like to come watch!
Thanks, Sheldon
STR-LGL-70
STR-LGL-70
Post  Wheelie58 January 26th 2015, 6:09 pm
STR-LGL-70 wrote:Keith,
Thanks, Sheldon
February 13-14-15
Wheelie58
Wheelie58
Post  68formalGT February 17th 2015, 6:29 am
Wheelie58 wrote:
February 13-14-15
How did it go?
Post  Wheelie58 February 17th 2015, 9:11 am
I had to cancel the trip. Just too much going on at the shop.
I will start at Gainesville on March 6-7 and then run the Gatornationals the following week.
Keith
Wheelie58
Wheelie58
Post  jbozzelle February 18th 2015, 12:29 am
Any chance you heading west to No Problem Raceway for the Jeg's Cajun Nationals in March?
Post  57custom February 24th 2015, 1:50 pm
I would love to see your car at Bradenton at the "Spring Break Shootout" 6/7/8 march  Have you ever thought about doing any of the NMRA meets? Smile
57custom
57custom
Post  old blue February 24th 2015, 11:32 pm
man that's one sweet build and the port work is amazing, congrats it just plain awesome
old blue
old blue
