carbs for 514 ci motor
+10
1970 ford maverick
kim
Mark Laczo
OldRed70
2fox
redtag5000
14 posters
carbs for 514 ci motor Empty carbs for 514 ci motor
Post  redtag5000 February 21st 2013, 12:02 am
what size of carb do i need for a 514 ci motor
redtag5000
redtag5000
carbs for 514 ci motor Empty Re: carbs for 514 ci motor
Post  dfree383 February 21st 2013, 5:24 am
street or race? tell us about the motor?
Post  2fox February 21st 2013, 6:39 am
At least a 1000 cfm 4150 style Carb , should just be enough
2fox
Post  bbf-falcon February 21st 2013, 8:17 am
I agree w/Dave that we need more info,but a 1000cfm Dominator is what is mostly used successfully.
Post  maverick February 21st 2013, 10:19 am
Several years ago, I raced the 514" Ranger with an 1150 Dominator. When I swapped on a friend's 1050, the truck slowed almost 2 tenths. I suppose it coulda been the carb tune, but the 1050 ran real good on my buddy's 500" Chevy. How high are you gonna spin this thing?
Post  OldRed70 February 21st 2013, 10:22 am
Wouldn't a 1000 cfm be to much for street use ?
OldRed70
OldRed70
carbs for 514 ci motor Empty cfm
Post  Mark Laczo February 21st 2013, 10:28 am
I run a HP1000 on a little 466" on the street and it works well.
FWIW Mark
Mark Laczo
Mark Laczo
Post  OldRed70 February 21st 2013, 10:31 am
Just wandering I am running a 950 and was thinking if I needed to step up . My engine is a 514
OldRed70
OldRed70
Post  maverick February 21st 2013, 10:33 am
I don't think he told us if it was a street deal or not. His avatar shows him next to a racecar, tho...
Post  kim February 21st 2013, 1:45 pm
Ideal carb for a 514 spinning 7500 RPM for drag racing would be 1300 CFM.
Same engine for street use, and 7500 RPM peak, looking at 1100 cfm
Bring the peak RPM down to 6000, 1050 domi for drag racing. Or a 950 for the street.
kim
Post  richter69 February 21st 2013, 1:57 pm
my 466 pumpgas street motor will have a 1050 dominator on it.
my 306" sbf race motor has a 950
my 563" bbf race motor has a 1450
Id go with an 1150 or even a 1250 if this is a lightweight racecar deal.......
Post  kim February 21st 2013, 2:03 pm
richter69 wrote:my 466 pumpgas street motor will have a 1050 dominator on it.
Agree, IF someone has the knowledge, patients, and dollars, bigger is better. They are a bit of a challenge to tune though.
Ive gotten 950HPs to work great on many 350 cu in combinations.
The average bolt it on and forget it guy, isn't going to love a carb designed to keep WOT vaccuum at .5" or damn close. He's going to want that 13" vaccuum combination that never takes a jet change or adjustment.
kim
Post  2fox February 21st 2013, 3:36 pm
I'm running that race demon 1009 cfm 4150 Carb. On a 408 11.7-1 , .700 lift with 200.shot turning 7800 rpms
2fox
Post  redtag5000 February 21st 2013, 3:42 pm
[quote="2fox"]At least a 1000 cfm 4150 style Carb , should just be enough
[/quote my car is a full blown race car, it is a 12 & 1/2 to one, it has a 709 cam , it has a 1250 QF on it now, it has super Cobrajet heads and much more, it runs good like it is, but i was wondering if i was holding it back by the way it is set up.
redtag5000
redtag5000
carbs for 514 ci motor Empty carb for 514
Post  1970 ford maverick February 21st 2013, 4:40 pm
[quote="redtag5000"]
2fox wrote:At least a 1000 cfm 4150 style Carb , should just be enough
What are your ETs now,do you race 1/4 mile ,or 1/8? ,what trans, gear ratio , convertor,tire size and weight of your car ?, Keep the 1250 ! Love the Mavericks, MavMan
1970 ford maverick
1970 ford maverick
Post  the Coug February 21st 2013, 5:17 pm
I ran a 1150 on my 492 and like others when went to 1050 it slowed....I am going to run a 1050 or 2 1050s on my Cleveland or go fuel injection with 8 2 1/2 in throttle blades ( hilborn stack injection ) a 289 will take a 950, I am thinking about trying a 1050 on it also
Post  466cj February 21st 2013, 5:43 pm
Years ago a friend had a 289 drag car, started with a 735, then a 850DP, then tried a 1050 dominator. The 1050 Dom was the fastest. Everyone said it would be too much, including me, but that little 289 like it.
Steve
466cj
Post  the Coug February 21st 2013, 6:40 pm
466cj wrote:Years ago a friend had a 289 drag car, started with a 735, then a 850DP, then tried a 1050 dominator. The 1050 Dom was the fastest. Everyone said it would be too much, including me, but that little 289 like it.
Steve
Steve it's funny how that seems to be, when it seems to big then it's just right... I am wondering what a 289 would do with 2 1050s on it? I know they like 2 660s, I might just have to build an engine to test this...
Post  maverick February 21st 2013, 6:45 pm
[quote="1970 ford maverick"]
X2 on the 1250. X2 on the Mavericks. Cool
Post  kjett February 21st 2013, 10:13 pm
I ran a 1150 on my 466 and it took every bit I could give it. The plan for the 488 is to break it in with the 1150 on the dyno then try a 1250 and see what makes the most power.
kjett
kjett
Post  bbf-falcon February 21st 2013, 10:29 pm
I agree w/ya'll on most of this thread. My ole Maverick was a 466 w/Ported DoveC's w/big compression and big roller (for 466). I went from a 1050 to a 1150 and it came alive. But it has a lot to do w/whats inside the engine imo.
Post  dfree383 February 23rd 2013, 3:34 am
For a set-up drag car a 1250 dominator or bigger, for a real street car with a 10:1 514, street gearing and a real tight convertor, I'd be looking a a 950 or 1000 4150 for crushing and good performance.
Post  Rich Osmond March 13th 2013, 4:15 pm
I have yet to install an 1150 (or larger) carb on any decent race engine over 450CI and not see a performance improvement. For the street I go with a 2 circuit dominator.
Rich Osmond
