Factory production Chrysler iron hemi head vs iron cobra jet
+12
4speed
Bret Powell
dutchman
GT300TD
QtrWarrior
16 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Factory production Chrysler iron hemi head vs iron cobra jet
I did not work on the heads. I am not at liberty to say what I may have done as far as I know.
Bret
Bret
Bret Powell- Posts : 133
No info necessary.Bret Powell wrote:I did not work on the heads. I am not at liberty to say what I did or did not do as far as I know.
Bret
schmitty- Posts : 4538
I wonder what adding 100 CI, 2 points of compression, and a 1250 carb would do on that SS 429?rmcomprandy wrote:4speed wrote:Sounds to me that it would basically come down to how much coin a guy has to throw at the hemi or the dooe-r. Generally speaking how much would a guy have to throw at the hemi heads to make the same power the cj head would pretty much maxed out (I know maxed out is a relative term).
Randy, if I were to send you both heads & said I want to spend 1500-1800 in port work on the cj's & then approximately how much would it take to get the hemi's to out power them. Would it be in the same ball park $$ or less,more? If a guy were trying to get to say 850+ hp w/ the 475ci 4150 carb what would it take, considering that the rest of the stuff done to the engines were built to accommodate that power level? or is there too many variables to give a good answer.-A
The cost of porting the cylinder heads would be almost the same as the CNC machine doesn't care.
I just had a pair of D0OE-R heads CNC ported and they need a bit of epoxy shaping just to get air flows close; (and that certainly isn't keeping the port volume of either head the same as was OEM produced). Brazing in the exhaust ports is the same cost and the Fords need it a whole lot more than the hemi heads do..
Most of the cost of that kind of power level would be in the rest of the valve train and the engine underneath them.
AND, of course, all the development time.
I can tell you for sure, that an 800 horsepower Ford big block with a CJ headed, single 780cfm 4150 carbed, 429 cubic inch engine is and has been done in NHRA Super Stock..
Gary Blair- Posts : 221
I know 557 inch and a ported set of Dooe-r's will run 5.70 @ 3200 lb.............. I did it at Bowling green and the cam had only 8 degrees of split and only 110 seperation.
Ask BooBoo.............
QtrWarrior wrote:I thought it was... Mostly Old Parts And Rust ..??
Motor On Pavement After Race!!
ThndrChkn- Posts : 2216
ThndrChkn wrote:QtrWarrior wrote:I thought it was... Mostly Old Parts And Rust ..??
Gotta tell that one to my 'nopower' buddies when they say 'fix or repair daily '
GT300TD- BBF CONTRIBUTOR
Page 2 of 2 • 1, 2
» Anybody ever put 440 Chrysler or 426 Hemi rods in a 385 series?
» cj block factory 4 bolt main can it handle more than other production blocks?
» Factory heads and intake
» RHP... Your source for ported factory iron...
» HEMI A441 heads vs Iron CJ's........Mom's Car
Page 2 of 2
