Schaeffer's oil.
whitefield
Schaeffer's oil.
Has anyone used this in there transmissions and if so what did you think about it ?
whitefield- Posts : 2244
Re: Schaeffer's oil.
the alltrans has been in mine since i put it in the car 5 years ago.............good stuff!
Schaeffers=good product.
Nevs- BBF CONTRIBUTOR
even though the atf is red its good stuff.....
I know most use it in the PG but how does it work in say a C4 or C6 trans ?
I bought some today as well as some Diesel oil he had !
Its what all the diesel guys use also......... I run it in my killer C4 as well......
Been running it for 12 years or better, In everything I have. Had there version of hy tran in the 557 ti tighten it up. They offer a winter grade and a summer grade that will help to fine tune if you need. Killer product.
IDT-572 wrote:Been running it for 12 years or better, In everything I have. Had there version of hy tran in the 557 ti tighten it up. They offer a winter grade and a summer grade that will help to fine tune if you need. Killer product.
The best, thanks for hooking me up on the Ernie's.
61coon- Posts : 1824
Your welcome...........
richter69 wrote:Its what all the diesel guys use also......... I run it in my killer C4 as well......
I got the oil to service my 7.3 and the trans fluid for it too ! Wasn't sure how the trans fluid would react in a C4. I am use to running amsoil compressor oil in it !
unless your wanting to thin the fluid the comp oil is the cats ass......., the Schaeffers 315 hyd oil is similar to the comp oil in weight Im pretty sure....
richter69 wrote:unless your wanting to thin the fluid the comp oil is the cats ass......., the Schaeffers 315 hyd oil is similar to the comp oil in weight Im pretty sure....
Got my oil Today and will be servicing the ole 7.3 engine and trans Friday. I also orderd some 20/50 for my Mustang and Fairlane!
I am going to continue running Amsoil compresor oil for my C-4 transmissions and c6's as well. Thanks for the input!
