E-85 tunning question
I'm contemplating switching to E-85. I was wondering if people are having luck running E-85 through there nitrous plates as far as tuning goes and also if corrosion is a concern. I've also been considering running a separate fuel cell/system and just keeping the spray on race gas, although packaging might be an issue. Thank you for any help/advice.
BLACKFOX- Posts : 15
Re: E-85 tunning question
Nitrous works great with E85 in the combinations I have run. Nitrous express has a good jet chart available on their site and the tech line is helpful as well. I have t had any corrosion issues with the nitrous plate or components.
Rich Osmond- Posts : 217
Nitrous and E 85 work great together as long as the tunes are correct and the timing is also addressed properly.. We have built a ton of E 85 stuff with great success.. Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
E-85 as fuel for both engine and N2O beats the heck outta having to run Race Gas and E-85.
Race gas is getting prohibitively expensive.
LovesDemCubes- Posts : 100
» carb tunning
» Beginner tunning questions.
» Pro-system SV-1 carb and nitrous tunning
» Oil pan question
» Oil pan question
