Nx gemini plate
Nx gemini plate
Any of you guys know someone that has used one of these with injected methanol ?
http://www.nitrousexpress.com/60075-10-dominator-gemini-twin-stage-6-alcohol-50-100-150-200-250-300hp-with-10lb-bottle.html
KY JELLY- Posts : 1530
Re: Nx gemini plate
put a gas enriched system on it.
the alky enrichment works good w a smaller shot, like a 150 or less. Anything over that use gas....... been there done that.
dont run nos w m5 either.
Get a sledgehammer plate from IS and be done w it..........
Re: Nx gemini plate
Oh really ????
What was the biggest shot ( gas enriched ) you did when running alky ?
John Myrick- BBF CONTRIBUTOR
Re: Nx gemini plate
I don't think my 5 " butterfly will clear that crossbar in the sledgehammer plate . I only want about 150 hp or so anyway . How much of that equipment do you need to fill your own bottles and such mr fabio?
Re: Nx gemini plate
trust me you'll want more lol. Honestly if the butterly is an issue a fogger would be the best set up.
I got 50 bucks in a scale, you need a freezer, a short line to connect the bottles, and a filter. 100 bucks should get it all. then all you need is a mother bottle. The lease on mine is 59.00 a year, contents is roughly 139.00 for a 64 pounder. I get roughly 55 pounds outta one without a pump.
look around for used bottles, everyone is going to the 15 pounders so lots of'10s arpind to be had for 100 -125 bucks or so.
Re: Nx gemini plate
John Myrick wrote:Oh really ????
150..... ish, the same jet will pick up more w gas enrichment.
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» Cam thrust plate and water pump baking plate questions
» BBF Starter Locator Plate and Steel Mid Plate
» Mid plate and motor plate for bbf ford-off set
» front motor plate and mid plate
