351 Windsor question
bb429power
GTmustang
351 Windsor question Empty 351 Windsor question
Post  GTmustang May 16th 2013, 9:23 am
When did Ford start putting Roller Cams in the Windsors? Do the blocks have taller lifter bosses like the 5.0's?
Gary
GTmustang
351 Windsor question Empty Re: 351 Windsor question
Post  bb429power May 16th 2013, 12:26 pm
I believe it was 85 for the mustang, the same block was used for the trucks but they didn't get the cam until 94. The difference is there are two raised bumps in the lifter valley. They drill and tap them for the two bolts that hold that bracket in. If you give me your number I can send you pictures of it. I drill and tapped mine and converted it to a roller cam. Very easy, just need shorter pushrods to accommodate the extra length of the lifters due to the roller tips.
EDIT- I saw windsor and thought 302 Laughing Stupid me. Never mind, but It was around 94 still for the trucks I believe.
bb429power
bb429power
Post  61coon May 16th 2013, 12:32 pm
1994 was the first year for 351w roller cam engines. The casting will be F4TE.
61coon
61coon
Post  waypastcrazy May 16th 2013, 6:38 pm
Yep 94 for the 351 with roller cam. f4 blocks
waypastcrazy
waypastcrazy
Post  torino501 May 17th 2013, 6:57 am
ford never put a roller cam in the 351 for the lightning.... never understood that one?
torino501
Post  61coon May 17th 2013, 7:42 am
torino501 wrote:ford never put a roller cam in the 351 for the lightning.... never understood that one?
I never understood that either. The latter part of 93 ford switched over to the "roller blocks",but continued to use a hyd. flat tappet cam. Basically the heads (GT40),intake and a little bigger throttle body were the only upgrades I am aware of on the 93-95 lightnings vs. Your regular 'ol 5.8L.
61coon
61coon
Post  Copperhead May 17th 2013, 1:32 pm
100% CORRECT
Only difference in them was the heads & intake. Everything else is/was the same.
FWIW,....
I've had 6 different 93 models and only two of them had the F4TE roller blocks.
Sad
Copperhead
Copperhead
