what's enough
 what's enough Empty what's enough
Post  quick 52 June 8th 2013, 1:17 pm
If I flow my nitrous fuel side with a 82 jet for 200hp @ 5.5 psi fp thru the solenoid and plate how much fuel should it flow in ounce for 15 seconds...
quick 52
 what's enough Empty Re: what's enough
Post  austin460 June 19th 2013, 3:23 pm
This should help. Might need to read it twice I did lol.
 This will give gpm which shold convert to lbs/hour and from there ounces/sec.
http://www.nescaracing.com/n2o.html
austin460
austin460
Post  austin460 June 20th 2013, 1:28 pm
This may also help.
http://www.efunda.com/formulae/fluids/calc_orifice_flowmeter.cfm?bcsi_scan_976e2f6fa34819ba=XWBzi1WwshuWmC9etn3E7UOpKsgDAAAArIGoAw==&bcsi_scan_filename=calc_orifice_flowmeter.cfm
austin460
austin460
Post  Induction-Solutions July 2nd 2013, 12:03 pm
quick 52 wrote: If I flow my nitrous fuel side with a 82 jet for 200hp @ 5.5 psi fp thru the solenoid and plate how much fuel should it flow in ounce for 15 seconds...
WAY TO MUCH... Wink
For a common plate tune of say 200 HP it is common to see a .073-.078 nitrous jet used. If you were to run a .082 fuel jet that tune would be VERY rich.. For that tune your likely only going to need about 95 to 105 PPH of fuel.. A .082 fuel jet at 6 psi will move around 165to 170 PPH roughly..
Hope this helps.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
