460 headers
FORDMUD
pat427
pigs521bbf
460 headers
i have 86' full size bronco.. making 460 engine swap.. i need some input on which headers to use? chassis exit or fender exit or hood exit?
pigs521bbf- Posts : 173
Re: 460 headers
There are a few different chassis exit headers, but none that I have seen with large enough tubes for a race engines. Maddog makes a nice set of fenderwell headers with 2" tubes. Schoenfeld makes some reasonable price upright headers with 2" tubes. If it were mine, I'd do the Maddogs, clean and fit good. I had a set that he did with a set of BBC flanges, and they were very nice.
schmitty- Posts : 4538
Re: 460 headers
schmitty wrote:There are a few different chassis exit headers, but none that I have seen with large enough tubes for a race engines. Maddog makes a nice set of fenderwell headers with 2" tubes. Schoenfeld makes some reasonable price upright headers with 2" tubes. If it were mine, I'd do the Maddogs, clean and fit good. I had a set that he did with a set of BBC flanges, and they were very nice.
you have any extras you wanna sell?? and you have a link for the maddogs?
Re: 460 headers
http://maddogheaders.net/
headers
power pro or pro power has a set up to 2 1/4 in for bbf very reasonable.
pat427- Posts : 33
Re: 460 headers
Do you guys think, the mud or body movement from the torque will hit or damage the header if it is fender well exit? I spoke with MAD DOG and he said, you need to maybe get at least 2 in body lift with the application... any thoughts?
Re: 460 headers
I have an 80 f150 with the maddog 2". The driver side header hits my tires. Ive ran 35x10.50 boggers and TSL q's. Its not a big deal but kinda anoying. The other side doesn't hit at all. Other than that they are nice headers. I asked him about doing some 2.125 but he said no.
FORDMUD- Posts : 290
Re: 460 headers
FORDMUD wrote:I have an 80 f150 with the maddog 2". The driver side header hits my tires. Ive ran 35x10.50 boggers and TSL q's. Its not a big deal but kinda anoying. The other side doesn't hit at all. Other than that they are nice headers. I asked him about doing some 2.125 but he said no.
alright the tires i am using is 39.5 but i am afraid to spend that money and have the damn tire keep hitting.. but have you tried a different header?? i am possibly thinking about putting the headers through hood.. but i don't know..
Re: 460 headers
I liked the headers through the hood, it cut down on the noise in the cab and I could also hear the drive train breaking
Mike R- Posts : 1381
Re: 460 headers
Mike R wrote:I liked the headers through the hood, it cut down on the noise in the cab and I could also hear the drive train breaking
what size would be a good tube? i am running a police interceptor head..
Re: 460 headers
I ran a set of the 2 1/8" Schoenfeld uprights on my 466 and they worked out quite nicely.
kjett- Posts : 1169
Re: 460 headers
The 2" maddog header, how did it sound? and did you make any fabrication on the frame or body?FORDMUD wrote:I have an 80 f150 with the maddog 2". The driver side header hits my tires. Ive ran 35x10.50 boggers and TSL q's. Its not a big deal but kinda anoying. The other side doesn't hit at all. Other than that they are nice headers. I asked him about doing some 2.125 but he said no.
Re: 460 headers
Large tube headers are not needed unless its in a more drag race configuration. .......take for instance. ..my build.....not your typical build. 521ci p51 headed street motor p51 heads matched to a dual plane?!?! And smaller headers.....goin in a 6000# f350........THESE NUMBERS WERE MADE WITH 1 3/4 HEADERS..642 hp at 5700...and 670 ft/lbs at 4200....
Imtruckinup- Posts : 23
Re: 460 headers
So is there an accepted engine size/power level that the store bought smaller 1 3/4" OD 460 header would start to hurt power/torque numbers, and a bigger tube would be needed?
DILLIGASDAVE- Posts : 2262
Re: 460 headers
Did you test with a bigger set?Imtruckinup wrote:Large tube headers are not needed unless its in a more drag race configuration. .......take for instance. ..my build.....not your typical build. 521ci p51 headed street motor p51 heads matched to a dual plane?!?! And smaller headers.....goin in a 6000# f350........THESE NUMBERS WERE MADE WITH 1 3/4 HEADERS..642 hp at 5700...and 670 ft/lbs at 4200....
I would fine it hard to believe it wouldn't pick up hp and tq with a set of 1.875 or 2 inch.
Re: 460 headers
You'll find horsepower up top but lose torquedown low.......depends on where your rpms will NORMALLY run......if its street..me personally I'd rather have the 10 ft/lbs of torque than 10 hp up top.....don't get me wrong horsepower is always good...but how often with you be able to bang through the gears all the way to redline where you'll finally see that extra 10 horsepower.....as far as larger headers...buddy of mine had a ser of 2 1/8 laying around........I did pick up 14 horsepower at redline.....BUT lost an averageof 30 ft/lbs from 2500-5000 rpm.......ill tske that 30 ft/lbs......heavy vehicles love torque
» Full length zoomie headers vs collector headers
» 4x4 Headers
» Blown boss 9 66' Fairlane
» please delete. SOLD
» Tube Chassis C-460 Headers
» 4x4 Headers
