Alky Plugs?
+6
79ford pickup
Moodyblues
10 posters
Alky Plugs?
I have converted to Alky. The plugs I was running with gas are NGK R5671A-9. What do yopu guys run in the alky setup?
Russ
www.russhoodinsurance.com
Russ
Re: Alky Plugs?
Russ, you know better, Alky is for drinkin' buddy......
Re: Alky Plugs?
dfree383 wrote:Russ, you know better, Alky is for drinkin' buddy......
Lol you've been in the desert too long. That camel nookie is affecting you.
Re: Alky Plugs?
when I went from gas to alky I ran the same plugs
Re: Alky Plugs?
same
Re: Alky Plugs?
u will have to run a wider gap than gas plugs
79ford pickup- Posts : 294
Re: Alky Plugs?
79ford pickup wrote:u will have to run a wider gap than gas plugs
Tell me more......thanks
Re: Alky Plugs?
Moodyblues wrote:79ford pickup wrote:u will have to run a wider gap than gas plugs
Yes, please tell us more.
Re: Alky Plugs?
a lot of people run a gap about .025 on gas and for what we have seen on alky the best is around .035 its faster than .025 in my truck and our other motor
Re: Alky Plugs?
79ford pickup wrote:a lot of people run a gap about .025 on gas and for what we have seen on alky the best is around .035 its faster than .025 in my truck and our other motor
For the benifit of others....what plug are you running and which 'box' and coil do you have? Also, how much quicker?
Re: Alky Plugs?
auto-lite AR-34 I think is the plug number. MSD 7AL3. MSD pro coil . and at least .050 quicker
Re: Alky Plugs?
79ford pickup wrote:auto-lite AR-34 I think is the plug number. MSD 7AL3. MSD pro coil . and at least .050 quicker
I was told just the opposite, close the gap with alky, to about 25, about 50 with gas, with msd box and coil.
342g- BBF CONTRIBUTOR
Re: Alky Plugs?
idk I just know the results on my truck and I have tried them right out of box make a pass then gap them and will run quicker but I guess every app is different
Re: Alky Plugs?
Would that be a AR-3934?
Re: Alky Plugs?
Gas or alcohol, gap shouldn't change much, gap is a result of the amperage/voltage of the ignition system, and the resistance to the arc by the amount of stuff you try to squeeze between the two electrodes. More compression, less gap.... at 18-1 it likes to blow the spark out at anything over .026" with a MSD7al3 and a pro-power coil.
kim- Posts : 700
Re: Alky Plugs?
342g wrote:79ford pickup wrote:auto-lite AR-34 I think is the plug number. MSD 7AL3. MSD pro coil . and at least .050 quicker
It's ...close the gap if you have a mag. ...050" with gas is waay wide i.m.o.
Aint nothing perfect....run what works
Re: Alky Plugs?
On my AR34"s I don't touch them,just screw them in after a quick peak.
Re: Alky Plugs?
i run NGK -8 or -9 from .020 to .030 with no problems. 7al2/propower ..........
Re: Alky Plugs?
I got a 7531 drivin an 8 plus box, im gonna crank up the gap this sat and see if we can get into the 5.0x's...........;-)
» Alky spark plugs
» SBF Alky timing and plugs
» Alky carb vs. Alky injection
» alky or c-16,c-14 vp?
» Alky Guy's!!!
» Alky Guy's!!!
