7.07 at 195 598, single carb running on one fogger 36/32
+9
D. Sea
Maulerman
capri-sun
Top Sportsman 514X
13 posters
https://www.youtube.com/watch?v=P_KICmsnjYc
Top Sportsman 514X- Posts : 41
Nevs- BBF CONTRIBUTOR
Re: 7.07 at 195 598, single carb running on one fogger 36/32
awsomrun ,, now thats gettin it done
capri-sun- Posts : 346
BREAKOUT?
Maybe I'm not up on the latest TS rules but how does one breakout in what I thought is a heads up class?
Maulerman- Posts : 5
Top Sportsman and Top Dragster are both bracket classes.........
wow impressive consistency w/ the spray !!!! great job man ...would you mind posting some details of your build and we would love to have some pics to drool over
Nice! and Congrats on the win!
D. Sea- Posts : 2768
Details and pics. Nice car and runs.
I'll post some pics up this weekend from my other computer -
Details - 02 Double Frame Rail Tube Chassis built by Lakeside Tube and Chassis - Dan Bytnar
Weight 2540 with driver (90 lbs over minimum for N20 assisted BB)
598 - A460 Block
GRP Aluminum Rods
Bryant Crank
Diamond Pistons
Comp Nitrous Cam
Blue Thunder Thor Heads and Intake
T&D Shaft Rockers
APD 1250 Single Carb
2 Speedtech Fogger Systems
Powerglide
Abruzzi Converter
Best ET - 6.87 @ 201.25 - Route 66, August 2009 at 1900 DA
Currently at the paint shop getting a total makeover - put it in the sand at D5 race in Earlville, IA, tore up the nose - decided it was time for a change!
598 - A460 Block
GRP Aluminum Rods
Bryant Crank
Diamond Pistons
Comp Nitrous Cam
T&D Shaft Rockers
Powerglide
Abruzzi Converter
Last edited by Top Sportsman 514X on November 12th 2009, 11:15 pm; edited 1 time in total
That sucks, as nice as Earlville is, it does get a little short down there on the east end! Sorry to hear, but glad its repairable.
Talked to the painter today - all ready for paint on Friday!
with a powerglide................dont tell Frank....lol.
It could be faster with one of my C6's!!!! well maybe !!
Frank Merkl- Posts : 1524
richter69 wrote:with a powerglide................dont tell Frank....lol.
Or Gerry ands Les.
TravisRice- BBF CONTRIBUTOR
Top Sportsman 514X wrote:Top Sportsman and Top Dragster are both bracket classes.........Maulerman wrote:Maybe I'm not up on the latest TS rules but how does one breakout in what I thought is a heads up class?
And depending on what part of the country & the racing circuit, Top Sportsman shows usually can be run on either a dial-in, or off a set index. Either way does use a breakout. As an example the TS circuit here in north Texas is run off a set index of 4.70 for the 1/8 mile.
DILLIGASDAVE- Posts : 2262
What kind of wheel base is you mustang?
86bigblockbird- Posts : 100
Who did your heads ? What will it run on the motor ? I'm swithing to the Thor heads now and have the same car @ 2350 lb & 598 with the A heads.
David
David
Dave T/S780- Posts : 5
» 6.90s (or better)single carb, NA, who's done it with a BBF?
» single carb vs dual
» Sideways single four carb??
» 1200 hp with single carb c-head
» Hot Rod Mag 1,000+ hp 600" single carb Kaase bulit 1994
