503 FMS A-Head Build
+7
79Puller
56Tbird
460pulling
11 posters
503 FMS A-Head Build Empty 503 FMS A-Head Build
Post  460pulling October 21st 2013, 5:03 pm
Well I have been gathering parts for around a year and here is my 503 inch A-head build for in a 4X4 pulling truck. And figured I don’t see many small cubic inch A-head builds so I wrote this up.
All machine work and assembly was done by Jet Boat Bob.
The Build consists of:
4.160" stroke Lunati 4340 crank
6.8" Eagle hbeam rods with arp 2000 bolts
FMS A460 block bored to 4.390"
FMS A460 10 bolt heads titanium intake and stainless exhaust
Trend 3/8” pushrods and Comp Cam 1.73 roller rockers
Jomar stud girdles
4.390" Domed Ross forged Pistons and Mahle file fit rings low tension rings
FMS single 4500 intake manifold with a 1” open spacer and a 1” Jomar power cone spacer.
Lunati custom ground solid roller cam (thanks Randy Malik)
Crane .904 solid roller lifters along with bronze lifter bushings
Comp Ultimate Adjustable billet timing set
Jeff Johnson billet two piece wet sump pan.
Moroso external oil pump setup.
MSD Crank trigger ignition with 7al2 and pro power coil.
Quickfuel 1250 Carb
GZ Sportsman Vacuum pump setup
I would like to thank Bob Hardison aka (Jet Boat Bob) for all the hard work he has put into this along with all of the info he has been able to share. He is a one stop shop and does the machine work in house to the highest standards utilizing top of the line equipment. From welding some fittings in the pan to machining the block he has sent me pictures and called about every little detail. We should have the engine on the dyno this week and see what it puts out. I will post some results after the dyno.
I would like to send out a big thanks to Kayla (aka the Boss), My father, Lem Evans, Randy Malik, Charlie Evans, Bobby Ziolli, and everyone else that has made this possible.
https://s1320.photobucket.com/user/460pulling/media/photo-2_zps781778da.jpg.html?sort=3&o=0
503 FMS A-Head Build Photo-2_zps781778da
460pulling
503 FMS A-Head Build Empty Re: 503 FMS A-Head Build
Post  res0rli9 October 21st 2013, 6:05 pm
waiting.Cool
Post  dfree383 October 21st 2013, 10:55 pm
Nice looking piece.
Post  460pulling October 21st 2013, 11:23 pm
dfree383 wrote:Nice looking piece.
thanks. hopefully it makes decent power.
460pulling
Post  56Tbird October 22nd 2013, 10:03 am
I saw it sunday Jesse.You'll be excited when you get your hands on it for sure. Nicelooking engine!! Congrats cheers
56Tbird
56Tbird
Post  460pulling October 22nd 2013, 10:14 am
56Tbird wrote:I saw it sunday Jesse.You'll be excited when you get your hands on it for sure. Nicelooking engine!! Congrats cheers
Thanks also gotta go out to you Dan for hauling my heads to Charlie.
460pulling
Post  bbf-falcon October 22nd 2013, 10:14 am
Nice looking piece Jesse. Picked he right shop,thats for sure. Can't wait for the results.
Post  Lem Evans October 23rd 2013, 3:33 pm
Pretty engine. Go luck to you and the engine. Cool
Post  79Puller October 23rd 2013, 4:56 pm
Jesse,
Good looking hammer you have there. You going the four wheel drive route now? What class you plan on pulling ?
79Puller
Post  460pulling October 23rd 2013, 6:34 pm
Thanks Rick
Thanks Lem. Lem I will be down there on friday evening and saturday. Maybe I will stop in if I have time.
Jason I am going to run the ig block class. They are having a rule meeting in the middle of January to finalize the new rules, but for now thats the current plan.
460pulling
Post  79Puller October 23rd 2013, 8:49 pm
What club, Full Pull, PPL or another
79Puller
Post  res0rli9 October 24th 2013, 5:48 pm
update:) Smile
Post  Lem Evans October 24th 2013, 7:22 pm
460pulling wrote:Thanks Rick
Give me a call when you get to town.....270-929-5295
Post  kjett October 25th 2013, 3:41 pm
Waiting on the dyno results. Want to see what this makes over my newer TFS 340 A headed 488ci deal. Neutral
kjett
kjett
Post  68formalGT October 26th 2013, 10:51 am
kjett wrote:Waiting on the dyno results. Want to see what this makes over my newer TFS 340 A headed 488ci deal. Neutral
Karl, are your heads the 10 or 18 bolt version?
Post  460pulling October 26th 2013, 2:47 pm
I am happy with the results for what I have in this deal. And couldnt have went with a better guy to do it. Jet Boat Bob has an exceptional shop with top of the line equipment. The engine made these numbers with "shrouded"valves to boot. 880hp at 7100 and 7200. And the torque was 707 from 6000-6200. Not bad for a budget build. I'm sure it will destroy the truck. This is with a safe tune on Mike Phillips dyno at Automotive Machine & Performance.
I will try and get a video and pictures up once I get home.
460pulling
Post  kjett October 26th 2013, 2:52 pm
Mine are 18 bolt heads but just using 10 bolts on a stock block
kjett
kjett
Post  68formalGT October 26th 2013, 3:04 pm
460pulling wrote:I am happy with the results for what I have in this deal. And couldnt have went with a better guy to do it.  Jet Boat Bob has an exceptional shop with top of the line equipment. The engine made these numbers with "shrouded"valves to boot. 880hp at 7100 and 7200. And the torque was 707 from 6000-6200. Not bad for a budget build. I'm sure it will destroy the truck. This is with a safe tune on Mike Phillips dyno at Automotive Machine & Performance.
Awesome results, waiting on the video!!!
Post  res0rli9 October 26th 2013, 5:01 pm
Good job, great #s
What compression?
Post  c.evans October 31st 2013, 7:26 pm
Congratulations Jesse, good dyno numbers and you should be proud of it. I'm sorry I missed you when you were in town, I went to the machine shop Sat. morning I missed you.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  460pulling October 31st 2013, 10:35 pm
Charlie,
I'm hooked now lol. One of them 600" engines look and sound nice. Might be back before I know it. Thanks again
460pulling
Post  badsnake306 November 12th 2013, 6:47 pm
nice numbers. how did that oiling system work out for you?
badsnake306
Post  460pulling November 12th 2013, 6:51 pm
Badsnake it worked very well. The only thing I added was a scavenge filter off the pan.
460pulling
Post  badsnake306 November 17th 2013, 10:34 am
460pulling wrote:Badsnake it worked very well. The only thing I added was a scavenge filter off the pan.
glad to hear that. very nice engine
badsnake306
