How much N2O on a stock block?
+15
nuclearcobra
Tennessee Bullitt
valleydawg
Barney
NOS42
fastford600
fastford
IcallhimGeorge
studly
kjett
Greg_P
gofastmerc
Ryan C
19 posters
Page 2 of 2 Previous  1, 2
How much N2O on a stock block? - Page 2 Empty Re: How much N2O on a stock block?
Post  valleydawg December 11th 2009, 1:58 pm
I have a 514 that I spray 150/250 on all the time (Speedtech) and have 78 runs on this engine. I sprayed 375+ (two systems) and ran a 5.0 / 141 mph in the heat but have only sprayed that much 3 times. Man I love the stuff...what else can you do to drop from 5.60 to 5.0 but I know I am starting to get a little greedy.
valleydawg
valleydawg
Post  Tennessee Bullitt December 11th 2009, 4:43 pm
valleydawg wrote:Man I love the stuff...what else can you do to drop from 5.60 to 5.0 but I know I am starting to get a little greedy.
Very Happy So were the guys on Wall Street Very Happy
Hey I am going to test the same here soon, well maybe not real greedy but hey if you can get away with it, then go for it.
Tennessee Bullitt
Tennessee Bullitt
Post  nuclearcobra December 16th 2009, 9:31 pm
I think my tune was off a hair Shocked How much N2O on a stock block? - Page 2 Th_IMG_7443 How much N2O on a stock block? - Page 2 Th_IMG_7429 How much N2O on a stock block? - Page 2 Th_IMG_7445 Just kidding this wase'nt from nitrous it was from 7k and 20w50 to cold Sad
nuclearcobra
nuclearcobra
Post  Tennessee Bullitt December 16th 2009, 10:32 pm
Ouch!!!!!!!!!! affraid Well I guess the block should have broke as well since it looks like everything else did, Oh wait it ain't a chebby.... cheers . I wonder how many BB chevy blocks came apart from a bad tune or a nitrous kaboom.
Tennessee Bullitt
Tennessee Bullitt
Post  nuclearcobra December 17th 2009, 8:03 am
Oooooo gross never a chevy here that was a 302 for my cobra 2 i burned a rod bearing to the crank and boom i never let it heat up soon as the water temp hit 160 i got to the line and did my burnout and staged then when i took off i shifted into 2nd at 7k and that was it holes in the pan i got out the pan was ice cold to touch so was the oil. It was a year ago Dec 14 at a tnt and it was 24 out plus my 2 hour drive there with an open pit trailor that pan was cold and i was stupid.
nuclearcobra
nuclearcobra
Post  Tennessee Bullitt December 17th 2009, 12:08 pm
Well atleast the 302's are really cheap to build.
Tennessee Bullitt
Tennessee Bullitt
Post  nuclearcobra December 17th 2009, 7:12 pm
I would'nt say any cheaper than a 460 ya just get more bang for your buck with a big block thats for sure.
nuclearcobra
nuclearcobra
Post  whatbumper December 18th 2009, 1:17 pm
The 1.80 first gear lets that big torqued motor eat. If you really want a good 2 speed go with a Rossler TurboGlide. Both of these allow you to run more gear to really pull the motor down. Seen some rediculous gains switching from a 3spd to a 2 spd and these are 3400lb+ cars that I am talking about.
Post  mach1 December 19th 2009, 6:20 am
Ive ran my 557 making over 1300hp with a stock block for 6yrs with no problems motor makes 900 na and 1322hp on the juice
mach1
Post  bruno December 19th 2009, 9:08 am
whats the details in the build ??
http://WWW.CKRME.COM
Post  richter69 December 19th 2009, 11:46 am
why does the glide make the car faster?
Lots of truth there.
Post  mach1 December 24th 2009, 5:10 am
stock block off set ground cast crank blue thunder heads 13to1 comp alum rods diamond pistons bullet cam solid roller made 897hp on the dyno and 1300 on a 400 shot running c-16 fuel
mach1
Post  the Coug December 25th 2009, 5:11 pm
The Glide does not need a 1.8 low gear the 1.74 or 1.64 are great you want to load the engine , these Big ford Engine build monster torque load the crap out of it and let the Torque work... also I love the fact that the Glide you have 1 shift and let her eat and not have to worry about having to hit 3rd gear.....much less chance of error during a run......But I DO SUGGEST you get a really Good converter or you will trash a cheaper one.....
Post  bigjohn2007 December 25th 2009, 6:16 pm
when people blow a motor with nos they don't tell they had a holley blue fuel pump on a motor that made 600-800 horsepower + 300 shot gas or the plugs were 6 months old,timing light old as the wax behind their ears or just don't know what the hell doing it always the nos. Before ANYONE starts using nos get someone like steve on here to go over their setup that includes fuel system,ignition system,timing and so on. what i am saying it always easy to blame the problem on nos and not on the real root of the problem.
bigjohn2007
bigjohn2007
Post  Ryan C May 13th 2010, 12:44 pm
Update: I've since put a glide with the stock 1.76 gear and a progressive system on the car and sprayed 200 leaving on 55 percent 1.5 seconds in and ran a 5.73 @ 122 with a 1.31 60ft.On 275's It felt like a sunday drive. I'm gonna bring it in a little quicker. I ran 21 degrees timing and there was no timing mark on the plug and fuel looked good. I'm going to add a degree at a time and keep my eye on it. Then go for a 275 shot then to a 300. Anybody think 5.40's are possible? I'm still working out all the bugs. Lol I will prob have a fogger before I put 300 on it. (I'm pretty sure I will be ok with my A2000 fuel pump)
Ryan C
Ryan C
Post  richter69 May 13th 2010, 6:59 pm
big jump from 5.70's to 5.40's, that thing gonna have to 60' real hard to get it done in the 1/8th.
Post  NOS42 May 13th 2010, 8:50 pm
he sprayed 55% of 200 shot at 1.5 sec in the run and ran a 5.70
if he ups the percentage and has it come in quicker in the run, say right after the 60ft mark and it hooks....it will go a 40....and might possibly not need 300
great job by the way..gotta luv when a plan comes together!!
NOS42
NOS42
Post  Ryan C May 14th 2010, 12:39 pm
Thanks, I just ordered a Fogger and it will be on soon. This will help with tuning especially because the runners on the victor intake are longer on the corners and shorter in the center. We are going to ramp it in a little quicker and leave out of the whole on a higher percentage. Trying to get some 1.2X 60fts. The car was only supposed to be a low ten second car. I shut it off before the 1000 ft. mark and coasted to a 9.24 @ 120 . . . I am very conservative with timing. I know there is a limit but I'm going to push my stock .030 over 2 bolt main block as far as I can only because people say it cant be done.
Ryan C
Ryan C
Post  NOS42 May 14th 2010, 4:05 pm
cant speak from experiance with a 302, but what a have read as well as you most likely is that you will be able to make the power but the block will fail. seems like the web is not strong enough for that amount of hit. you should try your same combo and attempt to "air it out" a little more....you might be surprised
NOS42
NOS42
Post  whatbumper May 15th 2010, 1:06 am
NOS42 wrote:cant speak from experiance with a 302, but what a have read as well as you most likely is that you will be able to make the power but the block will fail. seems like the web is not strong enough for that amount of hit. you should try your same combo and attempt to "air it out" a little more....you might be surprised
He's running a 545bbf. a factory 302 block will NOT run in the 5's at his weight........more than once. Wink I have seen factory 351's down in the fives but talk about cap walk.
Post  NOS42 May 15th 2010, 6:55 am
sorry about that....dont know where I got 302 from? I really need to pay more attention Embarassed
NOS42
NOS42
Post  Ryan C June 1st 2010, 10:32 am
250hp shot with the fogger leaving on 43 percent off the trans brake all on in 1.2 seconds... 1.28 60ft. 5.64 @ 119 the car stumbled a little at the end of the track (twice) so once I fix this problem it should 50 easily.
Ryan C
Ryan C
Post  bruno June 1st 2010, 11:55 am
Nice pass Ryan
Post  Ryan C June 1st 2010, 12:13 pm
Thanks Bruno! I'm workin on it! Lol
Ryan C
Ryan C
Post  valleydawg June 2nd 2010, 12:43 pm
That's moving on!
valleydawg
valleydawg
