Project falcon 393
+8
Dave C.
61coon
Mustang-junky
whitefield
johndickjr
12 posters
Page 2 of 2 Previous  1, 2
Project falcon 393 - Page 2 Empty Re: Project falcon 393
Post  johndickjr October 14th 2014, 6:28 pm
the coil-over shocks and springs  came with the kit i bought, no one knew what the rate is etc, but for what i gave for it $$ it was a steal, once i get car running ill get a good weight on front and rear and order some good shock and springs, if i cant get it to hook guess ill get out the cutting torch, i ran 11.70 on 26x6 inch slicks
johndickjr
Post  FalconEh October 14th 2014, 9:23 pm
Why not use the Cleveland heads? the valley pans are cheap, and with the shock towers gone you have enough room?
Post  whitefield October 18th 2014, 10:51 am
FalconEh wrote:Why not use the Cleveland heads? the valley pans are cheap, and with the shock towers gone you have enough room?
Budget build and he already has his heads and that would require a different intake too ! That would be a good set up if he was starting from scratch.
whitefield
whitefield
Post  johndickjr October 22nd 2014, 7:25 pm
towers are still there , just notched
johndickjr
Post  johndickjr April 15th 2015, 3:55 pm
falcon is getting a full update, i was not happy with the way the weld and install of the roll bar and ladders bars turned out..word to people that try to go cheap..DO NOT DO IT...just pay the $$ to a professional and have it done right, it is now cost me 3-4 times as much $ to have it redone
johndickjr
Post  johndickjr April 12th 2018, 8:31 pm
had a new cage installed, tubbed, rear narrowed...new strange strut and brakes put on, new firewall, new billet specialties rims
Project falcon 393 - Page 2 40957201432_b5c930fd67_z
Project falcon 393 - Page 2 40289971984_f855587559_b
Project falcon 393 - Page 2 40289966844_f8557b0017_b
johndickjr
Post  68galaxie April 13th 2018, 11:30 am
Sweet car!!
I think its a 62?
Cheers
68galaxie
68galaxie
Post  Mike R April 13th 2018, 6:32 pm
Good looking car John. Are you gonna go big block or stay with the small block?
Post  johndickjr April 13th 2018, 8:24 pm
Mike R wrote:Good looking car John. Are you gonna go big block or stay with the small block?
not sure, I have the 393 ive been running in my fox, in this car it will go 9.90 range or better
johndickjr
Post  FalconEh April 14th 2018, 12:11 am
Sweet Falcon ride...I really like the stance and the wheels extenuate the body lines Cool
Get'er done!
Post  dfree383 April 14th 2018, 7:36 am
Sweet looking car
Post  johndickjr April 15th 2018, 7:16 pm
FalconEh wrote:Sweet Falcon ride...I really like the stance and the wheels extenuate the body lines Cool
Get'er done!
it will go lower in the front once i get motor and tranny in it, the rear is maxed out and so is the front, once i get car done ill have to go back and order new springs
johndickjr
Post  johndickjr April 15th 2018, 7:23 pm
i have to decide what motor i want, i am wanting to get back into the local heads up stock block stuff , they have a class for my car now, option 1 is use my 393w but car has to be 3200 lbs because of the C.I and im on alcohol,and small block can use aftermarket heads option 2 is build a 466 BBF ,but have to use factory iron heads again car has to be 3200 lbs or option 3 is build a 306 sbf and because its under 321 ci the car can weight what ever it is and that will be 2400-2500 lbs with me in the car
johndickjr
Post  johndickjr April 15th 2018, 7:25 pm
68galaxie wrote:Sweet car!!
I think its a 62?
Cheers
yep, 1962, it has came a long way since i first got it
johndickjr
Post  AZFairlane April 16th 2018, 10:29 pm
John, Dart block with 4.125 bore, 3" crank, best heads you can afford. Spin it to the moon, oh by the way that works out to 320.7 cu.in.
AZFairlane
AZFairlane
Post  johndickjr April 17th 2018, 11:07 am
AZFairlane wrote:John, Dart block with 4.125 bore, 3" crank, best heads you can afford.  Spin it to the moon, oh by the way that works out to 320.7 cu.in.
has to be stock block
johndickjr
Post  pmrphil April 17th 2018, 12:31 pm
I've got a new Eagle 4340 3.100 crank left over from a project never done - that would put it in the 3-teens Cool
pmrphil
Post  johndickjr April 17th 2018, 12:57 pm
pmrphil wrote:I've got a new Eagle 4340 3.100 crank left over from a project never done - that would put it in the 3-teens Cool
cant use aftermarket forged cranks,just any factory forged or a aftermarket cast crank
johndickjr
Post  pmrphil April 17th 2018, 6:30 pm
The only forged factory crank was boss 302 - I think I have one in a core boss block. Also have 3.100 stroker ass'y -cast offset stock crank, Eagle 5.400 rods (2.00 chevy journal) and Ross flattops. This was the assembly that the steel crank was purchased for, then the customer said "nevermind, now I want a 347".
pmrphil
