Start Point
Start Point Empty Start Point
Post  geno January 5th 2014, 7:47 pm
[size=12]I have a IS fogger system that I bought off this forum. I need a starting point. Would 22/20 with 6.5 on the fuel be a safe start? 532, glide, 9 in converter and 4.86 rear???
geno
geno
Start Point Empty Re: Start Point
Post  geno January 14th 2014, 7:31 pm
What do you guys think???
geno
geno
Post  Larry T January 15th 2014, 9:58 pm
I cant remember what you said the motor specks were tell us again and what ignition system do you have.what fuel are you using?
Larry T
Larry T
Post  geno January 15th 2014, 11:41 pm
It's a 532 in a 2700 lb Pinto.  I  run 112 fuel. The ignition is all MSD with a digital retard box.  7AL2, trans brake, and a delay box.
Last edited by geno on January 15th 2014, 11:45 pm; edited 1 time in total (Reason for editing : change font)
geno
geno
Post  richter69 January 15th 2014, 11:46 pm
You shoulda got the tune up sheets with it.
If not there should be a serial number onit, call Steve andmthey should,have all the info you need.
no sense guessing when you have a flowed setup like that.
Post  geno January 15th 2014, 11:52 pm
It's the system that Bruno had on his car. IS could not help me because there is no numbers on the intake. Bruno will not return my calls. You can see the build on the IS web site. The intake that has the gray powder coat.
geno
geno
Post  richter69 January 16th 2014, 12:51 am
Imo a 22n 20f is gonna be fat, a 26 or 28/20 maybe closer. or a 22/18
Nicks too busy playin cabin boy i rekon lol.
Post  bruno January 16th 2014, 7:50 am
geno wrote:It's the system that Bruno had on his car.  IS could not help me because there is no numbers on the intake. Bruno will not return my calls.  You can see the build on the IS web site.  The intake that has the gray powder coat.
looking for tuneup as we speak .....
http://WWW.CKRME.COM
Post  bruno January 16th 2014, 7:54 am
there was a baseline tune in the fogger already when it went to Michigan ????
Post  richter69 January 16th 2014, 5:58 pm
Update
Post  whatbumper January 16th 2014, 6:46 pm
It'd asking for a 40 jet.
Post  geno January 16th 2014, 7:28 pm
I wanted to start fat and work from there. What fuel pressure should I use for this testing. Thanks everyone!!
geno
geno
Post  bruno January 16th 2014, 8:05 pm
no card , sorry I would call Steve he should have info on that intake
Post  geno January 16th 2014, 8:08 pm
Thank you Mr. Bruno
geno
geno
Post  whatbumper January 16th 2014, 8:11 pm
FYI: fat is not as safe as you probably think.
Fuel pressure will be jet dependent. Since your system is flowed the math is not that difficult. Just wait for Nick to get back to you after he speaks with Steve.
Post  Larry T January 16th 2014, 8:20 pm
what jet do you want to start with first a 20?if so start with 20nos/14fuel that is a 6 jet spread with the 6.5 fuel psi that should be plenty fat.
but then again if it were me I would work toward 8 jet spread with 5.5 fuel psi "too fat is not always safe"
Larry T
Larry T
Post  geno January 16th 2014, 8:29 pm
Will do - wait on Mr. Bruno ... Thanks whatbumper
geno
geno
Post  richter69 January 16th 2014, 11:12 pm
fat will get ya ashtrays a lot sooner than lean will.
Post  whatbumper January 17th 2014, 2:39 pm
richter69 wrote:fat will get ya ashtrays a lot sooner than lean will.
Yep
Over timed and fat are what we see most of the time in failures.  We don't have any customers running anything smaller than 36's and most are in the 48+ range and they all use close to the same fuel jet.  We do adjust fuel pressure so the ratios are what we want them to be and then read the plugs from there.
Post  geno January 21st 2014, 9:36 pm
Mr. Bruno, have you gotten any information from IS ???
geno
geno
Post  richter69 January 21st 2014, 11:08 pm
what jets were in it?
Post  geno January 21st 2014, 11:32 pm
It had 24/20 in it but I had no idea what power setting that was.
geno
geno
