Fox Lake 518 Build, Dyno, and Carb Test
I'm not much on watching plain ol' dyno videos, they aren't very entertaining. Fox Lake has videos which are pretty cool on a 518 they built and not sure if anyone has seen them. It's two separate videos that goes into the build, then a dyno, then a carb shootout... very well edited. Look like iron heads with custom made shaft rockers, too. No exact specs on the entire engine, but I thought I'd just post it up to share:
Build:
Dyno and carb shootout:
Build:
windsor- Posts : 1167
Re: Fox Lake 518 Build, Dyno, and Carb Test
why did I see two different heads on the engine,looks like they had efi castings then back to a carb casting(dove,dooe-r,d3's)....? then they dyno w the efi heads...?
torino501- Posts : 417
» 557 P-51 BUILD AND DYNO RESULTS
» 557 A-460 Heads Dyno Test,Do these numbers seem decent.
» 429 SCJ Build/Dyno
» 560 C460 Build/Dyno UPDATE
» AFR 552 build w/ dyno numbers
