uneven trailer tire wear
QtrWarrior
Wheelie58
Dave C.
Tore
uneven trailer tire wear Empty uneven trailer tire wear
Post  Tore March 15th 2014, 8:53 pm
I just drove 650 miles and got down to Charlotte NC . I have a 26 foot Dominator trl. dual axle. The right rear tire is wearing uneven. The outside edge is wearing uneven. What can be the cause and what can I do to remedy this??? Trl was empty coming down.
Tore
Tore
Tore
uneven trailer tire wear Empty Re: uneven trailer tire wear
Post  Curt March 15th 2014, 9:10 pm
Sounds like its not following the other tire. Bent axle maybe? Loaded crazy?
Post  Dave C. March 15th 2014, 9:56 pm
Tore, i worked on semi trucks and trailers several years ago. We aligned the trailer axles by measuring from king pin/ hitch to the center of the front left hub. Measure from pin to center of right front hub. After making both measurements equal , measure from the center of the LF hub to the left rear hub. Go the other side and measure from the RF hub to the RR hub . Move the axle around until the measurements  are the same . It should track straight  and not wear the tires unevenly unless something is bent.
Dave C.
Post  Wheelie58 March 16th 2014, 12:40 am
X2 on Dave C info.
Sounds like axle alignment.
Keith
Wheelie58
Wheelie58
Post  Tore March 16th 2014, 8:14 am
Thanks guys I kind of maybe thought it was an alignment issue. I never looked under the trailer to see if there is some type of adjustment .
Thanks Tore
Tore
Tore
Post  QtrWarrior March 16th 2014, 8:39 am
If it was an axle alignment issue... Wouldn't the left rear tire wear uneven too ???
I had an issue like this on one of my trailers.. turned out to be bent axle from hitting a curb or 2..
QtrWarrior
QtrWarrior
Post  bbf-falcon March 16th 2014, 9:37 am
QtrWarrior wrote:If it was an axle alignment issue... Wouldn't the left rear tire wear uneven too ???
I agree,maybe a bent spindle.
Post  dfree383 March 16th 2014, 10:36 am
I had an issue with my old trailer wearing tires. It would wear one side all wierd and I would replace them..... Then the other side would do the same thing. I couldn't find any issue. Replaced all 4 and the problem appears to have gone away.
Post  Dave De March 16th 2014, 11:08 am
Worn out spring and shackle bushings will do the same uneven wear. If you have this replace them with the bronze greasable bushings and you wont need to do it again.
When I bought my trailer the tire wear was bad and the rubber bushings were gone.
Post  Tore March 16th 2014, 8:11 pm
I was looking today and I only have 1 tire wearing uneven. I was wondering if it was a wheel bearing.
Thanks for the suggestions to look for.
Tore
Tore
Tore
Post  Larry T March 16th 2014, 11:53 pm
last fall I had a bearing go out and it wore out a brand new tire on the inside.or maybe that axel sliped when they tightened it up and maybe too far forward?
Larry T
Larry T
Post  Dave C. March 30th 2014, 10:06 am
Update
Dave C.
Post  Tore March 30th 2014, 10:51 am
Nothing as of yet as I haven't had a chance to take it apart. When I get time to pull it apart I will post what I find.
Tore
Tore
Tore
Post  bbf-falcon March 30th 2014, 1:04 pm
He's probably been busy playing w/his New (AWESOME) toy he picked up in NC. Show us all a Pic Tore. Wink
