How much will it weigh?
Need some help figuring out the weight
86 ford bronco
460 d9 stock engine,
d44 and 9 in axel swap
c-6 trans
(4)39.5x15 15lt boggers
gut the fenders
no side windows
no fiberglass top
no seats, just the plastic bucket seats (2)
any ideas how much this will weight?
86 ford bronco
c-6 trans
gut the fenders
no side windows
no fiberglass top
charchar1207- Posts : 31
Re: How much will it weigh?
About 4000
schmitty- Posts : 4538
4200-4500
lghting94- Posts : 762
any recommendations on making the bronco around 3800 lbs?
Skin the rest of the body, cut out the steel floor/firewall and replace with aluminum. But when you add a cage back in to keep the truck from crushing you, it will go back up some.
kjett- Posts : 1169
you can go to a truck stop they have scales here in VA there called CAT SCALES some do some don't the big truck stops most likely do they will give you a damn good number
Rabbit- Posts : 57
you can take the bumpers off and hood off mud will come from under why not from the top it will keep the motor cooler let her breath I would say take the doors off but I would keep them on
Rabbit- Posts : 57
