ring gaping for nos
ring gaping for nos Empty ring gaping for nos
Post  Larry T April 3rd 2014, 9:55 pm
has anyone used these rings akerly & childs 19147-5 HTD LT ? .043 1/16 3/16 ring packadge
question is:these are file fit so 4.500 x .009=.0405 is what is recommended for the top htd rings.instructions it dosent say for a certain amount of nos this is the amount to file per bore size as other ring sets do.
2nd ring is .007 per inch of the bore = .0315 special instructions say that extra clearance is needed when using NOS but dosent say how much.
I want to set the rings up for a fifty jet Wink
Larry T
Larry T
ring gaping for nos Empty Re: ring gaping for nos
Post  supervel45 April 17th 2014, 11:16 pm
You need to ask yourself if you are only going to stay with a 50Hp jet? If so I don't believe I would increase the gap. I have sprayed 150 on stock ring gap 4.36 bore and it was OK.
Post  richter69 April 18th 2014, 8:08 am
50 jet X 8
Post  Larry T April 18th 2014, 3:10 pm
richter69 wrote:50 jet X 8
FREEKNaaaaaa you get it Twisted Evil
I did some talking around it was said no more than .038 on each was needed but me being me I may want to go to a 60jet I set them at .040 Wink
Larry T
Larry T
Post  richter69 April 18th 2014, 3:13 pm
My last build was a na deal, rings gapped around 22 or so.... A 200-250 shot every pass for the last 2 years the top ring never butted.... New build both are at .036 and im gonna lay the dick to it.....
Post  supervel45 April 18th 2014, 5:34 pm
Burn, Teach me to AssUme. Should have known better, with that bore size. Wink
Post  richter69 April 18th 2014, 6:32 pm
prolly need trashcans to see a diff from a 50 tp a 60
Post  whatbumper April 18th 2014, 10:43 pm
richter69 wrote:prolly need trashcans to see a diff from a 50 tp a 60
We have some solenoids that will flow any pill you want.  Twisted Evil
Post  Larry T April 18th 2014, 11:47 pm
ok,thats got me to thinking I may not have enough solenoid.they are not the trash can's they are from fulton that has .125 orifice.i understand that size will only support 500/550hp I need to be above that hp level.... Shocked
Larry T
Larry T
Post  richter69 April 18th 2014, 11:58 pm
add another fogger......
Post  Larry T April 19th 2014, 12:41 am
that is an option I do have the bungs in for 2 kits on the new intake Wink I just did not want to let go of the money at the moment Neutral
Larry T
Larry T
Post  Frank Merkl April 19th 2014, 2:46 am
1 x foggers = good , 2 x foggers = real good , 3 x foggers = really realy fast !!
Post  Frank Merkl April 19th 2014, 2:53 am
if you have the bungs , PUT nozzles in them!! fast and cheap are no to be used in the same sentence! LOL
