Is this a Spun Cam Bearing???
jmac2332
Is this a "Spun" Bearing???
Can anyone tell me if this is just a bad bearing or if it is indeed a "spun" bearing?
http://instagram.com/p/mWzVNakwp5/
http://instagram.com/p/mWzPxBkwp0/
http://instagram.com/p/mWzLRWkwpw/
jmac2332- Posts : 2
Re: Is this a Spun Cam Bearing???
Thats a REAL SPINNER.
res0rli9- BBF CONTRIBUTOR
res0rli9 wrote:Thats a REAL SPINNER.
x2
That's not a bad one.....
My Dad showed the bearing to a Machine Shop guy and he did NOT think that it had spun. But he said he wouldn't be able to tell for sure until he saw the block. I did think it was strange that I could still read the FORD logo on the outside of the bearing...
jmac2332- Posts : 2
I had something similar happen years ago...
The bearing "stuck" to the camshaft, But it had not spun in the cam bore..
checked the block and the bore was good...
Put in new cam bearings and ran it for years...
Never did figure out what made bearing seize to the cam.
But, it had to be from a lack of clearance...
QtrWarrior- Posts : 2703
Lem Evans wrote:dfree383 wrote:That's not a bad one.....
It's not a good one either
It's more like the one on that Dove block of mine years ago, not the ones in the ablock!
dfree383 wrote:Lem Evans wrote:dfree383 wrote:That's not a bad one.....
I know what you were trying to say.....it was a lot gooder than it could have been.
That D0VE incident was way weird.....it almost looked like the damn bearing fell out of the housing bore.
You mean like these?? A429 heads, dropped exhaust valve head. Trashed the block but these came out of it after 11 passes. One reason my next engine will be going to west to be built. No oil pressure problems.
Or was this the result of the metal going through the oiling system from the failure. I would doubt it.
70FB- BBF CONTRIBUTOR
» Spun rods/mains?
» KING MAIN BEARING CLEARANCE'S AT PARTING LINE..?
» Keep eating #8 Rod bearing
» Spun Bearings
» Connecting rod length theroy......
» Spun Bearings
