Separate tank or cell
Does anyone run a separate tank and pump for nitrous.. this is what I would like to do run the engine on pump gas and add a separate fuel for nitrous... So the engine is running pump gas and the nitrous enrichment fuel would be race gas feeding only the nitrous side... Would like to use this system on my truck only a 125hp hit but also on my track car 300hp hit
quick 52- Posts : 612
Re: Separate tank or cell
I have 2 fuel systems on my truck. I bought a small 1 gallon cell and mounted it beside the radiator. This is where the race gas goes--- flows through a filter to my holley black pump then to a fuel pressure regulator and finally to the fuel solenoid on my plate. The fuel pump turns on when I flip my nitrous arming switch, which also activates my full throttle switch. System works great so I can keep the motor on pump fuel and not use soo much of the pricey stuff!
Jon
Jon
460bronco- Posts : 364
This is what I would like to do460bronco wrote:I have 2 fuel systems on my truck. I bought a small 1 gallon cell and mounted it beside the radiator. This is where the race gas goes--- flows through a filter to my holley black pump then to a fuel pressure regulator and finally to the fuel solenoid on my plate. The fuel pump turns on when I flip my nitrous arming switch, which also activates my full throttle switch. System works great so I can keep the motor on pump fuel and not use soo much of the pricey stuff!
Jon
I also have a t-fitting w/ a male quick connect fitting so that I can flow the fuel side of my plate w/out unhooking any lines!
This is what I had built for mine, 1 side is for alcohol injection system, the other is for Nitrous system:
right side of tank is for C-16, left is for the Alky.
make sure you "vent " the tanks/cells...
quick 52 wrote:Does anyone run a separate tank and pump for nitrous.. this is what I would like to do run the engine on pump gas and add a separate fuel for nitrous... So the engine is running pump gas and the nitrous enrichment fuel would be race gas feeding only the nitrous side... Would like to use this system on my truck only a 125hp hit but also on my track car 300hp hit
Yes, as you can see it's very common.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Steve would this be safe with a 300hit... This the combo 427 sbc 11.4-1 comp. running engine on pump 93 gas and nitrous side c14 tune is 95n 81f 5.5psi fp 22* total timing if needed can run c16... truck 472 BBF 10.2-1 125hp hit comp 93 pump gas and nitrous side 110 renegade tune 65n 52f 5.5psifp 28* total timingInduction-Solutions wrote:quick 52 wrote:Does anyone run a separate tank and pump for nitrous.. this is what I would like to do run the engine on pump gas and add a separate fuel for nitrous... So the engine is running pump gas and the nitrous enrichment fuel would be race gas feeding only the nitrous side... Would like to use this system on my truck only a 125hp hit but also on my track car 300hp hit
» 429/460 Overheating Issue
» efi hat for factory tank or non efi tank
» Stef's dry sump tank $200 OBO
» Dry Sump Tank
» 5 stage tank
» Dry Sump Tank
» 5 stage tank
